designthis
NYS
2023 F150 Lightning Lariat SR Black 8/21/23 blend
Builder
This update was different for me. I got a message on my screen about 24hrs in advance letting me know I was going to receive a software update at a scheduled time. In my case at 1am. I got the message every time I started her up. The software updated without a hitch. And from what I could tell, it has made my Lariat‘s stereo sound significantly better. Less center channel, more refined treble from the front tweeters. Better overall sound. No complaints.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
Mine has always been center heavy, I look forward to checking this out tonight.
davehu
hot springs, AR
Got mine a couple days ago. can't tell any difference. the background noise referred to is almost certainly pertaining to background noise when speaking on the phone. There are methods using frequency equalization that can reduce background (road) noise but anything done to music, radio broadcasts would alter the fidelity.
Mashedtators
2023 Lariat ER
Got this today. Not really a noticeable difference. The sound is still dominated by the center channel on the dash.
thequackenbush
Ryan
Marketing
This is the first audio update I’ve gotten; bought a 23 lariat er in April of this year
Haven’t noticed a major audio update, however upon receiving it my front power train stopped working and I was down to 56% power. So major panic attack- taking my first family road trip in 2 days
It seems likes it’s back on now (an hour or so later) so who tf knows
Dinozero
Kentucky
2023 F150 Lightning ER Lariat
Got this update today.
Not sure how it could be the latest update and I still don’t have my mph sign moved yet
And during the whole manual download/update process, the PL6100 was powered on and set to maintain 13.5V across the jump points in the frunk. This is also the first time I've tried a completely manual update and used the PL6100 while doing so.
Does anyone see anything obviously wrong in what I'm doing,
I thought an inhibit update required all doors and frunk to be closed. Did you have frunk open when powering with Clore?
I have also used a power supply at times but i hook into the battery compartment and close the frunk. Never been an issue with pinched wires.
Also remember the FDRS lookup guys (@rugedraw ) can tell you why an update failed.
Install aberrations happen, I've had a couple over the past 2 years, you're probably ok, enjoy the trip.
Jim Lewis
San Antonio, TX
I thought about that in hooking up the power supply and didn't see any info in a cursory search on the forum whether the AUD update required going into Inhibit Mode. I thought perhaps if Inhibit Mode were required, I'd either get an admonition flashed on the screen in advance as happens with scheduled automatic updates, or I'd get a failed update advice as we used to indicating a prior process (or whatever the language was) had interfered with the update. Instead, I just got "! Not Completed" - not very helpful feedback. Perhaps my mistake was turning the vehicle off while the download was occurring. Maybe to get the advance notice to turn everything off, exit the vehicle, close all the doors, etc., the vehicle has to be on? (or in automatic update mode?).
@rugedraw and/or @Mike G, what's your advice on whether the frunk can remain open for OTA updates that require Inhibit Mode or when programming the truck with FDRS?
Here's what Microsoft Copilot AI says about the requirement the frunk be closed (it draws heavily from online postings on this and other forums and typically does a reasonable job of summarizing and inferring from various posts):
You
Does the frunk of the Ford F-150 Lightning need to be closed for OTA updates that go into Inhibit Mode?
Copilot
For Over-The-Air (OTA) updates on the Ford F-150 Lightning, the following conditions generally need to be met [3] [5]:
  • Your vehicle is stopped and parked.
  • Your parking brake is set.
  • The update is scheduled for before or after 12 a.m. (not exactly 12 a.m.).
  • Your vehicle's ignition is off.
  • All your doors are closed.
While it's not explicitly mentioned whether the frunk needs to be closed, it's reasonable to assume that it should be, as the guidelines specify that all doors should be closed. If you're having trouble with OTA updates, some users have found success by starting the truck in the FordPass app and driving it [1]. However, please refer to the official Ford guidelines or contact Ford support for the most accurate information.
Source: Conversation with Copilot, 7/31/2024
  1. Troubleshooting Over-The-Air (OTA) Updates When Pre-Conditions ... - Ford
  2. Why did the Software Update not start for my Ford?
  3. Possible Solution for Failed OTA Power-Up Updates | Ford Lightning ...
  4. Ford F-150 Lightning OTA Tracker: Every Update for Ford's Electric ...
  5. How To Get Failed OTAs To Install | ⚡ Ford Lightning Forum ⚡
  6. en.wikipedia.org
VTHokies
Jason
‘26 Chevy Silverado EV Max Range
Got this update today as well…
Not needed for an OTA for EV's. Updates that require the vehicle to be inhibited will draw juice from the HVB to the LVB during the update. In most cases, the LVB has a higher SoC after the update than before it. Not the case with the ICE vehicles and not sure if the hybrids do it, but the EV's do.
With FDRS, if you will be doing many updates or long ones like the CMR and PSCM/IPMA modules, then a power supply is needed. If a single simple module update pops up in my truck, I'll just do it with no power supply. The updates that require a USB are done with the vehicle on, so no power supply needed for those, either.
When it comes to FDRS updates: When in doubt, use a power supply.
Jim Lewis
San Antonio, TX
@rugedraw. Thanks as always for the very helpful info. I will put it to good use! One remaining item that would still be interesting to know is whether the frunk needs to be closed for any type of update. Would that be included as a "door" as the MS Copilot advice attempts to infer for Inhibit Mode where all doors should be closed?
I took your first sentence, "Not needed for an OTA for EV's" to refer to the need for a power supply, not whether the frunk can remain open.
