Powertrain malfunction/reduced power
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
I got my 2023 lightning in march of 24 with 200 miles and 9k plus miles later I get a power train malfunction/ reduced power message and could not drive the truck. Took family to the mall. I had to remove the 12 volt battery to reset, this was a week ago. Well tried to park the truck properly this evening and the same problem again. This is exhausting, repeated the same process to get it to move. Taking it to my dealer this morning. I can’t imagine it happening while my wife or kid was driving.
Ford F-150 Lightning Powertrain malfunction/reduced power 1723204214064-3z
Ford F-150 Lightning Powertrain malfunction/reduced power IMG_5158
Ford F-150 Lightning Powertrain malfunction/reduced power IMG_5159
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Good Luck with the Dealer. Keep us posted.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello, I would like to see if I can assist you with your powertrain concerns. Could you please send us a message with your VIN and mileage?
H8N-8NT-EZ
Jason
2023 F-150 Lightning XLT
Could be a faulty ground connection somewhere.
Victorog
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Hello the truck totally stopped moving right by a dealership. VIN#. Mileage is 9658. I am left without a vehicle now. This is unacceptable especially when I paid $90,000 for a truck. The dealership does not know how long it would take to get it fixed.
Ford F-150 Lightning Powertrain malfunction/reduced power 1723243088825-ml
Did the dash and all electronics in the cab go out or just the traction battery power?
Victorog
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Just the powertrain failure and high voltage battery warning
Ford F-150 Lightning Powertrain malfunction/reduced power 1723250257797-m5
Ok, I hope you have answers sooner than later,
BTW, you need to Start a Conversation with the Ford Motor Company profile, hover over the avatar, you will see a link pop up to create a conversation with them share the details again.
Victorog
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Thanks I did.
Temix
F150 Lighting Lariat
As a veteran of two battery failure seasons, let me share a tip: if the dealer doesn't offer you a substitute vehicle, just rent one and bill all your expenses—including fuel—directly to Ford.
Victorog
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Will do
Thank you for the update good advice. ??
Victorog
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Update on powertrain malfunction! The battery array was the problem. It appears it really doesn’t matter what mileage you may have on your vehicle, dealer states the problem could happen at 1100 miles or 20000 miles. Once that happens you will be needing a new battery array which has to be approved and ordered. Considering there are no other lightnings ahead of you it would get diagnosed in a week. Wait time for the battery pack delivery is 3 to 4 weeks. Then it takes 2 days to install and reprogram the vehicle. In my opinion you may be out of a vehicle for about 6-8 weeks. In my case this is week 7 my truck broke down on 8/9/24. all recalls and battery issues were completed on 9/24/24 I still don’t have my truck back due to problems with the driver seat leather changing color. I had to wait 2 weeks to get a loaner vehicle. So good luck!
GoodSam
Good
occupying space
Most likely it is just one of the 9 battery modules that contain 11 (#9 has 8) cells, where each cell is made up of 4 or 5 pouch cells depending on if SR or ER. If one of the 96 cells is some percentage lower than the others, that is (one of the causes) when the PM/RP trouble code shows up. Hope they get the shipping done more quickly than quoted. @Ford Motor Company should have these battery modules ready to ship, close by, in every area of the country.
Victorog
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
In my case the whole thing was replaced. ER platinum.
