Intermittent aluminum crunching/ shifting sound under driver side. Help!
iam7foot1
JP
Lake Tahoe, CA
22 Mustang Mach E GT PE & 23 Lightning XLT SR
Retired Tech
Hi all! '23 XLT Lightning SR owner for about a year now. About a month ago, I started hearing an intermittent sound once every 20-30 minutes coming from under the driver's side. The best I can describe the noise is like a loud aluminum soda can crunching. It sounds like aluminum is popping in and out of place. I took it to the dealer and they thought it might be the wheel bearing. They replaced the wheel bearing and it still makes this sound.
It doesn't always come from the exact same place. It's always under the driver's side, but sometimes on the side, sometimes under my left foot and sometimes kind of behind my seat. Any ideas? It's driving me crazy and I want to get it fixed while it's still under warranty.
Thanks in advance for any ideas!
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Started about a month ago at Lake Tahoe, perhaps related to the cold? Like a partly empty plastic pop bottle with the cap on under the back seat? :rolleyes:
iam7foot1
JP
Lake Tahoe, CA
Retired Tech
Thanks for the reply! I thought that maybe it might be related to the cold as well but it seems like it doesn't matter whether it's cold or not. It's VERY loud and the truck's body is made of aluminum. I'm thinking it's one of the aluminum panels under the truck shifting and wondering if any other Lightning or F150 owners have experienced this.
we've had extremely rare reports of missed welding of panels, I hope that's not your situation.
iam7foot1
JP
Lake Tahoe, CA
Retired Tech
Thank you for letting me know about this possibility. Do you know how I would go about finding if this might be happening for me?
I don't, the incident I recall was related the forward part of cab where panel was not welded correctly and waterproofing failed leading to water in the cab.
I'd take a close look at rock shields under the truck, look for debris caught between them and the cab floor, motor units or battery pack.
If you've taken it off road and scrapped the guards look for damage to it that could be causing this sound.
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Particular sized branches in a wheel well?
From my experience with an XLT SR, there's no substitute for getting on the ground and having a look underneath the cab and/or bed (in park, e-brake on, power off, wheels chocked, vehicle chained to the ground as a captured beast...I live on a steep hill). Then wiggle various metal and plastic panels, not real hard, just enough to see what's loose.
Of course, a careful look around the cab first with gentle prodding of plastic parts wouldn't be a bad idea either, and it's easier. My XLT came with a substantial piece of plastic wrapper stuck between the bed and cab which didn't make much noise but would have if it were slightly thicker.
Here's hoping your noise is coming from a random bit of something and not a defect in welding or fastening...or you can just tighten a screw or two and fix the problem...or the chipmunks that have taken up residence decide to move elsewhere and don't develop a taste for orange wires.
waasiw
'24 Lightning Flash
There is a recall for some trucks which did not have a suspension bolt torqued properly in the left front. If the suspension comes apart, the vehicle will pull to the left and stop suddenly. you can look up your vin. My truck has this recall and the dealer does not yet have a fix for it, but I'd head straight to the dealer, (do not pass go, do not collect $200 in Monopoly speak) in case yours is coming loose!
https://www.ford.com/support/how-tos/recall/recalls-and-faqs/is-there-a-recall-on-my-vehicle/
iam7foot1
JP
Lake Tahoe, CA
Retired Tech
Thanks for your reply! I'm not seeing this recall anywhere with a Google search for any Ford trucks. Can you please provide a link for this?
Maineiac12
Iowa
iam7foot1
JP
Lake Tahoe, CA
Retired Tech
*Update*
Took my truck into the dealership last weekend. After a few days of working on it, they couldn't replicate the sound so I took the tech on a drive. Within a minute, the aluminum crunching noise happened and the tech told me in 20 years of working on Ford trucks, he's never heard a sound like this. He said it sounded like "body flex". He said that he can type the issue into his Ford Dealership database to see if any other techs across the country have had similar issues and he found no similar cases. Lucky me.
He said they would order a new underbody panel and call me when it arrives.
Has the truck been on n a lift? It seems like they should be able to find something if they poke around a bit.
iam7foot1
JP
Lake Tahoe, CA
Retired Tech
Yes it has been on a lift and they haven't been able to see the problem. Its just a tiny shift in the paneling that makes a loud noise like when you squeeze an aluminum soda can. It's worse in cold weather. They said there isn't any damage, it's just a panel that maybe isn't as strong as it's supposed to be.
