Riverant
MA
2023 F150 Lightning Lariat ER
Happy to report that all my FDRS updates appeared to go smoothly. My 75a Powermax kept my LVB voltage comfortably above 12v the whole time.
I am running into an issue where FDRS isn’t clearing some of the software updates after completion (PSCM, RFA, and the front audio module). I’ve reran all and ran into zero issues but still on the list. I did clear the vehicle cache and rescan the VIN to no effect.
Am I good to just ignore these?
Pitbull2o08
Ohio
What’s the consensus on Nano vs mongoose?
chillaban
2022 F-150 Lightning Lariat
My PSCM did clear (in the past I’ve seen this too) but RFA and ACM did not. I think you are fine to ignore them unless you got an error during programming or there’s DTCs that persist beyond initially clearing them.
Mike G
N. AL, USA
The ACM and RFA have been problematic since the day they came out around the middle of September. They have refused to drop off the list for everybody who've tried them.
The PSCM not dropping off, at least initially for me, was an issue I believe to do with the IPMA not being configured during it's update, and then the PSCM update taking place. What I did that worked for me was I ran the IPMA Configuration separately afterwards, which then also re-ran the PSCM configuration...and then the update dropped off the list. However, for two other forum members I was messaging this morning, that hasn't worked. They've both tried running the IPMA config to clear that update off the list, and that didn't fix it. So now I'm not sure what's going on with that PSCM update.
Mike G
N. AL, USA
It's been reported that the Nano does work to perform updates. But there's a catch. Apparently (and this is anecdotal, as I don't have one) what happens is the data that is returned back to the cloud that the Nano reports ends up corrupting the Ford server side (I think it's asbuilt data they're talking about). So since the cloud data gets corrupted you aren't offered any more updates until those modules that were updated using the Nano get updated again (PMI?), using a Mongoose or VCM, or some other adapter that is fully J2534 compliant.
This is what I've seen written about the use of the Nano over the last few years and is the reason it is no longer recommended as a suitable adapter to use for updates.
The Mongoose costs what it costs because it doesn't have those issues.
Riverant
MA
What's the process and timeline for configuration? My FDRS license is expiring shortly. Is it worth it to try the configuration or does the update clearing not matter?
mr.Magoo
2022 Lariat ER, AMB
Make that three, I ran the updates the other day and followed your your recommendation to run the configuration without any luck getting it cleared/removed from the available updates.
Yea, I recommended the IPMA config procedure to several people based on Mike's experience and it does not seem to clear the PSCM from the list. I would not stress it, though.
shelnian
Ian
Seattle
I use one of these. Performance matches the mongoose. Recommend updating firmware with VCI Manager before using.
And I would strongly advise you or anyone from using that tool. If you used this and nothing bad happened, consider yourself lucky.
Ford F-150 Lightning ECU module programming guide using FDRS 1735847284626-n9
shelnian
Ian
Seattle
It's a cloned VCM2, that's why VCI Manager can load the latest Bosch firmware onto it. I've used it with absolutely no issues, including updating the IPMA and PSCM modules. Also use it with FORScan.
As the ad indicates, you shouldn't use the cheaper single board clones for updating modules, they only work well for diagnostics.
I see what you're saying....I read it wrong. I still wouldn't go this route personally, but I do see what you're saying.
Pitbull2o08
Ohio
Why use this instead of the $100 nano?
Mike G
N. AL, USA
There are a lot of reasons and at least one of them I already posted in response to your previous post about it.
You can do a search on the ICE forum and easily come up with threads like this.
Or maybe this post from one of the legends in the area of programming.
It's been said many, many times before. You can use the VCX Nano but if you do there's a very good chance that the data it reports back through the interface to FDRS, and ultimately back to the cloud will be corrupted. Which means your vehicle won't be offered future updates for that module until a PMI is done with a compliant device to sort it out. And there are certain modules that if programmed with the Nano will be bricked.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
I finally got around to doing the IPMA update today. It took about 3 hours but was otherwise uneventful. There did not seem to be any configuration errors, but after it was done I cleared/retested for DTCs and reran the IPMA configuration tool anyway. I did briefly get a SSN message on the IPC toward the end but it cleared on its own and never came back. I did not have to disconnect the 12V for anything.
Like others, the PSCM update installed but did not clear from the list afterward. I did a quick test drive and BlueCruise engaged and seemed to work normally.
It sure is nice when things work as they should.
