Charging cable run under garage door
rescuetruck
f150 lightening
Has anyone one come up with a good way to run their ford charging cable under the garage door. I park my new flash outside the garage and just had my charger installed today. I’ve noticed that the garage door doesn’t close all the way and I also want to try and protect the cable.
Jseis
Washington
My garage door had one small ~2” section missing the lower seal at the doors left edge. I wrapped the charging cable tightly with inner tube rubber and secured with a wrap of duct tape. Always set the cable in the side and thus placed it w/in the seal gap. I did this for a few months until I relocated the charger and parked the truck in the garage.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Some folks have installed a small thru-the-wall door in the wall (think dryer vent). I have found the size of the rubber bulb on the bottom of the door makes a difference, I can close the door at home without any apparent damage to the cable, altho I lay a similar diameter pipe nipple next to the cable just in case, and the seal is tight enough to discourage mice.
broncoaz
Cape Cod, MA
Works absolutely great. You will need to replace rubber gasket at bottom of the garage door with a thicker one.
https://a.co/d/fUdQEfx
I’ve been considering this as a solution. My garage has a concrete lip that the door closes in front of, I’m not sure how well the Undoor would work without grinding a little concrete on the lip. From an install video it seems like I’d need to install something of similar height on the other side so the door stays even. I could make a block at home with a rubber plug to mimic the function.
We have been swapping which EV is parked inside based on which one needs to charge, option B is to charge the Lightning outside with the garage door open on a weekend day when we are home.
MrLoganRoss
Logan
Seattle Washington
No need to have something else with similar height on the other side, as as long as you use the proper gasket, and you set the garage door stopping point. Worst case scenario, is that you add a second Undor to the other side. They come in a box of two anyway.
Danface
Dan
Central Mass
2023 Lightning XLT
The rubber on the door is short so I just put a 3/4 board next to the cable and put the cable next to the rail to prevent the door from possibly hitting the cable
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Spigen DuraPro Cable Garage Door... https://www.amazon.com/dp/B0BB3JR65W?ref=ppx_pop_mob_ap_share
I had this before getting my charger installed outside and it works flawlessly. You have to use this, it protects the sheathing and prevents premature wear and failure.
broncoaz
Cape Cod, MA
Their website and installation videos recommend installing both to prevent garage door damage. Not a big deal, but I’d never use one on the opposite side of the door away from the charger.
Ford F-150 Lightning Charging cable run under garage door IMG_7230
☝ This is the answer. It's a permanent solution, doesn't damage the door or cable, and keeps critters out. The only downside is you have to adjust the door and install a new seal. It's a one or two hours job. Some people might not be comfortable doing that.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
I have the Undor system too and it works great. The door seal was a pain in the butt, not the end of the world though. And I only have one side installed, with the new seal and adjusting the travel it seals up pretty well.
csukoh78
Nope
SE USA
I did not change the seal out, felt it was unnecessary and the door still maintained water tightness and no bugs ever got in. I would just use this protector and call it a day.
