dr1983
dennis
2022 Ford Lightning XLT
Security Advisor
Does the the new Q4 need the extension you made, sorry if i overlooked it. I have a 2022 xlt with lane keep but not ACC but i have forscan. Thanks in Advance
You do still need the extension. I don’t really have any time until May to do one, but there is a guy on discord who said he was interested. I’ll ask him what he charges.
have you already ordered your ACC parts?
Also comma has been shipping a lot of the v1 harnesses lately, so I guess no one needs to buy extension components until they get the harness and see if it’s a v1 or v2
yes they will be here around January 17, dnd if you could ask i’d appreciate it.
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Would you be able to make a harness for the Comma? I have a 22 xlt with lane keep but not ACC. I do have forscan if that helps
I can make it. D.m. me
FLSpartan04
Daryl
23 F150 Lightning XLT ER
I’ve got the components for the v1 and v2 harness if anyone needs them. Including the back ordered pins (whatever’s left of the 100 I ordered after butchering a bunch trying to crimp them ?).
BennyTheBeaver
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
I'm going to order the unit. Can anyone sell me a harness so I don't get the errors? Also, has anyone been able to get Navigate on Openpilot to work?
Ajzride
Alan
Houston
Eng
Comma killed navigation because it was so terrible. Allegedly to make a return in 2025 after the rewrite it.
itsjmod
Jason
2022 F150 Lightning Lariat
Software Engineer
Not sure where to ask, but if anyone is making extensions to the Q4 harness, I will be glad to pay any fee + shipping to have one made for my 22 Lightning Lariat. Love the device and don’t have a lot of spare time to order and make the proper connections for all the errors and blind spot sensor failure (due to the harness obv).
I’ll prolly get around to it sometime later this year if not, just thought I would check :)
*it’s the updated harness with USB-C
JerseyMike
Allentown, NJ
2022 Ford Lightning Lariat SR, 2" pucks, P275/65/20 Nitto Recon
I second this, just got my comma device (initially only intending it for road trips in wifes escalade but it works great in the lightning). it adds what seems like bluecruise to backroads and works well (although it does seem to hug a bit to the drivers side...not sure if there is a way to fix that) but I do get errors until it starts up that go away.
BennyTheBeaver
You'd probably want to use the BluePilot fork as the standard OpenPilot or SunnyPilot you use with the Escalade won't work as well with the Lightning and you will see things like hugging corners or ping ponging. BluePilot also allows you to fine tune all those parameters.
JerseyMike
Allentown, NJ
Thanks,
I am using bluepilot, staging 2.1
still waiting on Escalade l&p harness
reading up on it I may try switching from North Dakota to FarmVille or blue diamond 2 as others online report success with those
BennyTheBeaver
If you are using BluePilot then you can adjust the Ford parameters in the settings on the device and that should help with hugging shoulders, ping ponging, and holding lanes during turns. Play with it on your next, relaxing, highway drive.
JerseyMike
Allentown, NJ
it seemed better last time I drove so will play with it some more, its excellent on the highway btw although BC was great as well (I have 1.3)
JerseyMike
Allentown, NJ
going to extend the harness myself, have the alex guide (but the newer harness so no need to cut the initial wires and loop back, just planning on extending all wires and putting resistors on the canbus wires....orange, green, blue and pink).....I have the following that I am going to buy:
one other issue that I thought of, with the new v2 connector the plug from the odb2 to the panda box is no longer connected with an ethernet cable.....it has a small plug...if I extend the wiring so that the box is up behind the mirror then I don't think it will reach.....I could extend it or I guess go without it (supposedly you don't need the odbII connector)
do I have that right?
watts/up
23 Pro SR
Note: the following is incorrect. I’ll update shortly with a revised diagram based in Ajzrides explanation.
I went through deciphering how the extension cable works just this afternoon. As I understand it the black Comma junction (Panda?) box would go down near the OBD-II plug (below the A-pillar) and the extension cable you're building would run from there up to the rearview mirror, connecting to the Q4 harness. You would need to also run their long 9.5' USB-C cable from the black junction box up to the 3X.
