DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT
ZSC100
Zach
Tulsa, OK
Electrical Engineer
So I popped off the connector on the driver's door and it looks like I don't have the wires on my 2024 XLT EG-311A :sadface: I'm hoping that either the wires are just different for 2024 or that it isn't hard to add them.
@ZSC100 where did you get the wiring diagram from? I'm trying to locate the same for 2024. Thanks!
Back then I was getting them from an awesome parts guy at a local dealer, ,but I've since realized a 72hr subscription to PTS on a dual monitor computer with fast internet is the way to go. Just spend a few hours and download(print to PDF) all diagrams you can think you'd ever need.
https://www.motorcraftservice.com/
Once logged in go to "service info" on the top menu bar, select 72hr Option and once you've paid you sometimes have to log out, wait 10min then log back in, to access it use the "my subscriptions" tab. It's not a very friendly UI, but it's Ford so that's to be expected :(
dcshoes23
Thanks so much @ZSC100 , that was a huge help. So, it looks like everything is the same. The last piece of the puzzle is the firmware. I would probably need the firmware from a 2024 Flash. You wouldn't happen to know where I could get that as well?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yes, for that you need to contact Jesse @Jesse-Infotainment
I'd say talk to him directly if a different BCM firmware is needed he will know. If indeed a different one is needed If you could start a new DIY post titled something like
"DIY: Installing Passive Entry To A 2024 F-150 Lightning XLT EG311A" with access to the firmware for others that would be awesome.
dcshoes23
Thanks for the help again. I will definitely make a post once everything is verified working. :)
jwharvey1820
Jordan
2024 lightning
Ford Tech
For anyone doing this on a 2024 xlt i just got mine completed and working.
Parts you need for this project are:
The harness listed Previously
PL3Z-14631-G
Handle listed previously
ML3Z-1522405-DCPTM (includes the passive button/antenna module)
I used a bronco handle and swapped covers so i did not have to cut mine
M2DZ-7822405-CB
I used this wire to run the 4 wires to the drivers door handle
https://www.amazon.com/dp/B0CFJXMDT3?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
And some pins for the connectors. i will list the pigtail part numbers so you can get exact pins
BCM - JU2Z-14S411-DA
Body harness to door - JU2Z-14S411-BB
I contacted @Jesse-Infotainment for assistance with programming and final touch ups but everything works perfect!
I would be happy to assist anyone with helping get this done.
If i were to do it again, i would not buy the door harness. I would run the 4 wires from the bcm to the body/door connector and then run the 4 wires from the door side of the connector and install a pigtail for the door handle. this would probably save you about $100-$150. i will list the pigtail part numbers below. I am listing the pigtails so you can get the pins from them so you have exact pins for the project. If you have access to pins or scrap harnesses you will not need them.
Door handle pigtail - FU2Z-14S411-ANA
Male Door harness - RU2Z-14S411-ATA
Female Door harness - JU2Z-14S411-BB
Here is the wiring diagram
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740597550574-ng
Door handle connector
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740597590059-b7
Male and female door harnesses
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740597627051-z2
Bcm
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740597666577-3m
dcshoes23
PL3Z-14631-G
M2DZ-7822405-CB
Bcm
Thanks for posting this! I'm about to do it myself on my 24 XLT but the wrong door handle was shipped to me and I'm still waiting for the replacement.
I have planned to do it the way you suggested where I'm running my own wires in the door between the handle and the inside of the door. I got the connectors for the door handles, that were posted earlier in this thread, off of AliExpress.
The part I'm a little unsure of is running the wires from the BCM to the driver's body/door connector. When I had unplugged the harness to see if I had the wires, there wasn't much wiggle room with the harness. Was it hard to get the pins into the harness with such little space? Also, do you have any tips and/or photos of how you ran those wires?
Thanks again!
jwharvey1820
Jordan
2024 lightning
Ford Tech
Thanks again!
No, it is tight but it is pretty easy. When you separate the connector like i have pictured below they slide right in. you have more room than you think. I then tied up the harness and ran it below the dash under the a/c evap case. Try to tie it up behind the gas pedal and above the steering column. Remember this is part of the body harness dont attach it to any part or run it through the dash because if the dash ever has to come out then the wires will have to be cut.
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740600976196-ux
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740600976241-wo
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740600976279-tb
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740600976319-6a
dcshoes23
Thanks for those details. I didn't realize that it slides out like that. What about the other end that goes in the door jamb. Any trouble or tips for that end?
jwharvey1820
Jordan
2024 lightning
Ford Tech
If you reference earlier in the thread they show a pretty good description of how to remove the door jam housing but once you get it out and connectors disconnected you can pull the door harness into the door and out the speaker hole for easy access. The body side has about 4 inches of slack so once again it’s not a ton of room but plenty to get the job done. If you run a coat hanger through the body hole where the harness comes out you can fish the wires through pretty easy. If I have a chance tomorrow I will take some pictures for you
dcshoes23
Good to hear it's easy to get the wire through with the coat hanger. That was the last unknown I had. I feel like the install should go pretty smoothly. Hopefully the handle comes soon. ?
wighty
NY
M2DZ-7822405-CB
It's been a bit since I've followed this thread...
Are you saying you bought 2 handles here? Or you went with the second one instead of the first?
jwharvey1820
Jordan
2024 lightning
Ford Tech
I bought both handles, the ML3Z-1522405-DCPTM is the F-150 handle but it is only available in primed not textured black. The M2DZ-7822405-CB is the bronco handle, the internals are different but the handle cover is the same. i took the primed cover off of the f-150 and swapped it with the Bronco. im going to list the bronco one on ebay or marketplace because it is a good handle, just wont work for the f-150. You can absolutely cut the handle like the OP but i didnt have the confidence that i was going to make it acceptable for my ocd lol.
jwharvey1820
Jordan
2024 lightning
Ford Tech
I actually used one of these to get the harness through under the dash and through the door jamb. It was much easier than i anticipated!
Ford F-150 Lightning DIY: Installing Passive Entry To A 2022 F-150 Lightning XLT 1740655072043-by
watts/up
23 Pro SR
Hey everyone. Does anybody know if the touch sensor request PID names were renamed or changed? I've finally had the chance to wrap up installing Passive Entry on my truck and when viewing live data (oscilloscope) neither of my doors (I did both driver and passenger handles) show up. I have not done the firmware update yet.
Overview: I did the driver's door handle last fall and was able to get it to show up by observing the LK_LF_LK_TCH/UL PIDs but now it doesn't after adding the passenger door handle today and retesting (hadn't tested since last fall). Thinking it was maybe a FORScan issue I upgraded (v2.3.65) and then I couldn't even find those PIDs to listen for. Reconnecting and not loading my previous profile the closest I could find was THS_DR_LF_L/U but those don't work either.
As an aside, the driver door open/close PID does work but that appears to be renamed to AJR_DR_DRV for me.
Any thoughts?
