Start up and shut down sounds intermittent
Some folks have suggested it has to do with the LVB state of charge getting to a point that modules don't boot in the intended order, leading to the dull tones instead of the fancy tones.
Well. I just got a check engine and only 62% motor power. So probably right.
Could be related to an update, have you had any recently, what was your last one?
Why do I have cool start up and shut down sounds sometimes. But most of the time not?
https://share.icloud.com/photos/09djwOu0XMhdFTC-3MEoP_Yqw
Is it silent most of the time? The four chimes is a seatbelt warning. If you are wearing your seatbelt while starting it should be silent.
Sometimes the seatbelt chime sounds like a 1998 Crown Vic; like a buzzer behind the dash. That's when the LVB is low. At least that's the theory.
Definitely, four ding-a-lings when starting while drivers seat belt is not latched.
