YouTube App on Lightning Not Working Anymore
LSUT1GER
Slidell, LA
Computer Engineer
My YouTube app used to work on my 23' Lightning Lariat ER but not anymore. I'm successfully connected to my T-Mobile hotspot but no YouTube. Any thoughts or fixes?
Ford F-150 Lightning YouTube App on Lightning Not Working Anymore YouTube App on Lightning
Ford F-150 Lightning YouTube App on Lightning Not Working Anymore Wireless Availabl
Ford F-150 Lightning YouTube App on Lightning Not Working Anymore Lightning Connected to my Hotspot
Ford F-150 Lightning YouTube App on Lightning Not Working Anymore Speedtest_For Lighting Hotspot
I assume you've tried power cycling the truck? You can also reboot the center screen by holding the right seek button and the volume down (the outer buttons at the bottom of the steering wheel) for ~10sec.
davehu
hot springs, AR
my experience wit h the youtube app has been inconsistent. It seems to work fine at home connected to the home wifi, and although I have used a few times with my phone as a hotspot, just as many times I couldn't get it to work at all. I DCFC only a few times a year so it's not a show stopper for me, but I have learned not to count on it.
abcut973
Anthony
Denham Springs
I would say reset your screen. If you have wireless connectivity then youtube should work. I just tested mine successfully.
Unless it is an issue with Tmobile and in this case you just need to switch to AT&T. ?
I used the built in YouTube app on Monday morning via my Samsung Galaxy S24u hotspot, also T-Mobile,
Double check that the truck didn't try reconnecting to the projection SSID instead of your hotspot SSID.
