dww
- First Name
- David
- Dec 10, 2023
- San Antonio, TX
- F150L, Tesla 3P, YP
Ok, Sorry. I thought I had seen a post saying the rears speakers were not from the rear amp in B&O.You all need to ensure you clarify which system you are talking about - they are all powered differently.
The B&O 8 speaker, all 4 doors, the center dash and sub are powered by the Amp in back. The front tweeters are powered by the ACM/HU. When you upgrade with an amp on this system you can use the wiring to the 4 doors, but you have to run wires from the new amp to the tweeters. You don't have a center speaker in most after market systems, so it just sits unused. The wiring diagram is the same as ICE and located here - https://www.f150gen14.com/forum/threads/tweeter-wire-not-in-door.14881/post-305440
The 6 speaker lower end system has 4 audio outputs and the front tweeters and front doors get the same signal on each side. Wiring diagram and discussion in this thread - https://www.f150lightningforum.com/forum/threads/pro-audio-upgrade.8460/post-307711
The B&O Unleashed the font tweeter and rear doors are powered by the ACM/HU - the rest are from the amps.
