Grumpy2
- Nov 23, 2022
- Central Oregon Coast
- 23 F150 Pro SR
- Occupation
- Retired Hvy Construction
Who puts children in the front seat?
Who blames parents for a simple software fix?Who puts children in the front seat?
Automatic windows have been around for a long time. Do you really think there isn't a fail-safe engineered into them?And don't get me wrong, this is a totally a "beast" of a truck and I am very happy with it, but no I am not going to trust the programming. Case in point, I am glad the latest update fixed one our window issue, but I am 100% positive the "feature" of automatically rolling the window all the way up will result in the death of many children. All it takes is sticking a head out the window and pulling up on the button. The force required to stop the window is more than enough to snap a little spine or fracture a hyoid. All for convenience?
PS All the way through this, I am not sure what is throwing the truck back and forth (surging). Difficult to see how the chains could allow the surging when the bars are tied to the hitch. What is providing the slop need to allow the surge? Adjustments and weight balance will help porpoising and steering control, but again folks, that is not the problem. It is surging, hence, probably software.FYI the surging is not the same period as any porpoising. I can deal with that. Bush league. This is different. Like two overlapping sine waves of different frequency, perhaps even in harmonic resonance with chain length. Do you follow me?
Over the years, I've read of other members overloading or putting it close to capacity, none reported a surging situation that I recall.It is surging, hence, probably software.
Wow! There we go. Some knowledgable info. I will get back to you.Over the years, I've read of other members overloading or putting it close to capacity, none reported a surging situation that I recall.
Did your Lightning come equipped onboard scale? (some builds had it deleted due to lack of supplies).
I'm curious if there is an erratic output from the weight sensor, that's feeding the algorithm bad data and leading to a surging sensation.
Is the readout stable, you might see slight variations, sometimes the scale reset fixes that.
If you have it, go to the scale menu, reset it to baseline [EMPTY], you can calibrate the expected passenger, cabin and bed cargo loads to offset the available capacity for tongue weight.
Attach the trailer, review the tongue loads impact on the scale, with & without the weight distribution hitch supporting the load, is the scale indicating overload conditions?
Adjust your WDH & ride height to it's optimum settings to get the tongue weight into spec.
Really? Guess you missed the go weigh the truck and trailer at the CAT scale...Wow! There we go. Some knowledgable info. I will get back to you.
Perhaps the scientist just needed more detailed steps instead of us coming across as opinions.Really? Guess you missed the go weigh the truck and trailer at the CAT scale...
Towing a 10k RV with Max Tow (10k) and extended batt. Have chain-style WDH. Tires are all pressured up etc etc. Cruise is off.
Starts surging when I hit a rolling bump. Not doing more than 55 mph. Feels like it is a brake controller software issue but I have turned the sensitivity all the way down and it does not improve. Could feel like a surge brake oscillation but I don't have surge brakes. Hitch moves a little in the receiver but I don't hear any sharp knocking like that would be the problem. Surge is far too big for it to be just the hitch anyway.
My best guess (judging from the sloppiness of Ford's programming and lag of the onboard computer) is that the truck is sensing a sudden forward or rearward motion and electronically reducing throttle input, resulting in a harmonic resonance (oscillation).
BTW surging is a straight forward and straight back motion, and it is extreme enough to do damage. Experienced advice would be appreciated.
