F150 Lariat calibrate travel trailer
Livin4today
Jus
Ford F150 Lariat
I purchased a new travel trailer, and I am unable to calibrate my truck with the travel trailer when I'm at the step that says to go in reverse, my truck won't go over 4 miles per hour. I did not had this issue with my other 2 travel trailers. Does anyone have any insight into why the truck does not go over 4 miles Per hour when backing up when the traver trailer is attached?
jdmackes
2023 F-150 Lightning Pro
The sensors should turn off when the truck detects the trailer. This is a new one on me, I don't know why it would limit your speed like that. Does it give any sort of error? Is this only during the calibration period?
Livin4today
Jus
Ford F150 Lariat
Yes, it is during the calibration process. Forward driving programs then it tells me to drive in reverse but it won't excelerate. The only warning is the calibration says to drive between 5-24mph but I can't go faster than about 4mph so it won't allow me to complete the process. I have programmed it two other times with travel trailers but I haven't had this issue before.
Use SYNC to make a customer feedback report.
cal
Cal
Battle Ground WA
2022 Lightning, Tesla Model S Plaid
What does this calibration do?
Livin4today
Jus
Ford F150 Lariat
the calibration is to set up the Pro Trailer Backup Assist
Maineiac12
Iowa
Does it still require the sticker on the trailer? I haven’t done one of those in a while.
Livin4today
Jus
Ford F150 Lariat
yes, I completed all the steps: entered measurements and when the calibration says to drive forward, it works. Then it says to drive in reverse and that is when I have an error. It says to drive between 5-24 mph but my truck is not accelerating past 4 mph so it fails to set up
