Options for removing running boards
Dave Miller
2000 Ford F250 7.3 Power Stroke, 2024 F150 Lightning Flash
General Contractor
I hate the stock running boards, I’m tall so I don’t need them to get in and out. Getting out sucks because if I don’t step on the running boards my leg rubs on the board and dirties my pants. I originally removed one but realized that the battery hangs down and looks like crap. I’m thinking about installing the electric running boards and just not plugging them in, but that seems like an expensive fix, anyone got any ideas or suggestions?
21st Century Truck
Martin
FYI - these OEM running boards help protect the truck's body during turns when there are hard-to-see obstacles, especially on the passenger side.
I am thankful for my OEM running boards when I made a right turn two months ago into an open parking lot I know well... I cut the turn a little too sharply and the right side rubbed against, and slightly moved, the freestanding concrete divider marking the entrance gate.
My running board completely protected the truck's body. I stopped as soon as I felt the rubbing, cut my turn a bit wider, and then inspected the damage. There literally was none other than a horizontal mark on the rubber edge of the running board, despite me having moved the concrete divider's end a bit to the inside of the parking lot line.
My running board's rear-facing edge light assembly did pop off and was dangling by its circuit. All I did was grab an (I think) 10mm socket + ratchet, loosen the securing bolt, and pop the running light back on. It now works like it always did.
As wide and tall as these trucks are, I sure became a friend to our OEM running boards after that li'l mishap.
So have to ask - you said the running boards get your pants dirty, so you removed one. Why are you wearing two pairs of pants?
Oh, I get it...
Ford F-150 Lightning Options for removing running boards nevermind
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
watts/up
23 Pro SR
The regular AR running boards are nice but I don’t think they hide the battery sufficiently. The XLs would but are even more expensive. For what it’s worth, I have those and would recommend them if you like the “rock slider” look.
WilliamRobert
happily retired!
That’s not actually the battery, it’s a cover to protect components attached to the frame.
WilliamRobert
happily retired!
You’re correct. I was just simplifying my answer.
I think it’s also shaped like that for aerodynamics, possibly a good candidate for an aftermarket replacement that’s more aesthetic .
Dave Miller
General Contractor
Whatever it is, it’s ugly and when you take the ugly running boards off, bam there it is!
Maybe I need to have something custom fabbed up like Bill did on the show Texas Metal.
acbarba
Enrique
Assistant Fire Chief
I’m with you on this one!
Old Aviator
Larry
WPB, FL
22 Lightning Platinum 06 Magnum SRT8 23 Ocean One
Consultant
Amp Research! I changed mine because they were too high to be useful as a step and with a little ice and snow they were very slippery.
https://realtruck.com/b/amp-research/v/ford/f150-lightning/2022/
Love my AMPs. My Platinum was a demo with fixed boards so I replaced them. Seems many fail to mention to also buy the optional AMP 3 way switch! It allows you to lock them up, lock them down, or leave in auto mode. Handy in car wash since the prep guys with power washer can clean them if they are down BUT don't forget the retract them as soon as that's done and you start moving. Left mine down 1 time and the front cap on the drivers side got ripped off. The noise it made was thankfully far more than the actual damage. Luckily you can buy replacement caps and they just snap into place.
RLXXI
3rd rock
Automotive Technician
I put Amp Research on my other truck and they'll go on this one as well. Same reason for both trucks, stock boards are too high and tight to be useful. Almost busted my behind so they came off the truck.
Power running boards are so much more useful than the fixed ones. They drop down much further and come out farther making them actually useful as a step. It actually makes you want to use them rather than just stepping over them.
PJnc284
Garner, NC
Love my OEM power running boards. Took forever to find one that had max tow with the power running boards. They were only like $255 over the standard fixed boards.
Athrun88
Toronto, Ontario, Canada
How are the power boards with snow and ice build up from driving? My brother has power boards on his PB Lariat and they're non functional due to electrical and snow/ice/moisture issues which is why I was happy my lightning came with fixed boards.
