CRAIGC540
Craig
Moreno valley
Technician
Thanks I really like the black one. I have the lightning blue volume cover and the black would look better than silver in my opinion.
I just read it doesn't light up like the silver one.
I'm learning back to the silver and find a blue cover like the radio volume knob that I have.
mr.Magoo
2022 Lariat ER, AMB
The letters still light up, but yeah, the Escape dial (silver) has a blue light ring around the base of the dial whereas the Maverick and E-Transit does not.
ENDianDigital
Ian
2023 F-150 Lightning Lariat
Here's my shifter setup...
I didn't necessarily like the existing designs as they were a bit "chunky" and made an attempt to get it more OEM looking.
BIG thanks to @ENDianDigital, without his design/kick in the butt I probably wouldn't have done this, it started as a few mods and turned into a complete redesign.
Main differences are that the shifter is located at the front (the cable is long enough if you cut/push out the strap holding it to the side wall).
The shifter is tilted 10-15 degrees.
You dont have to cut the tabs.
It accommodates the Escape and E-Transit shifters.
I ended up using the E-Transit shifter, being black, it doesn't stand out as much as a chrome would.
I painted the tub with a graphite metallic and dusted it with flat black to try and match the color/look of the cup holders, followed up with a matte clear.
And, yes, I'll post the drawings, this was basically the prototype and theres a few changes that I'd like to make before posting them.
Amazing work, great job!
So is it just using the back two bolts and the pressure of the trim piece to secure it in lieu of the front console bolts?
21st Century Truck
Martin
IMHO this might well be true, as the vertical front-to-back rotation movements of the OEM shifter stick would necessitate front as well as rear anchor points for the OEM shifter body, and the rotational shifter eliminates this front-to-back force input.
CRAIGC540
Craig
Moreno valley
Technician
21st Century Truck
Martin
mr.Magoo
2022 Lariat ER, AMB
I feel kind of dumb because I have no idea what you're referring to.
The "tub" is using the back two bolts and the front right one to secure the tub.
I have a hole for the front left one as well, but the shifter connector is right above the bolt so it's too tight to get a screw/tool in there.
I did do a reverse bolt and got it attached from the back side / underneath, before realizing it was a really bad idea and that any dealership coming up on it would hate you forever, so I took it out and that one front, right, bolt holds it just fine.
The shifter use all three mounting points, I got a thread insert thingy for my soldering iron and pushed in three M4 inserts. The shifter is TIGHT so you may not have to secure it further, I just figured better safe than sorry. But I ran a PLA print for 2w without securing it and it was just fine.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 20250528_042952
Bigred
Southeast TX
23 Lightning XLT ER
Finally got the 3D printed tub today after ordering in March after reading your OP. The maker ManionMakes on Etsy got slammed with orders after this mod hit the forums, both for Lightning and ICE F150's. I was able to get your linked shift knob when it was still $30 back in March. That part has also become harder to find and more expensive as this mod has become popular ($275 now !!).
Installed everything this afternoon when the tub arrived. Just like everyone else on this thread, I LOVE the result! It is a little more of a PITA to install on my Pro trim and XLT if you have that due to having to remove more trim pieces to gain access. In addition to the two side trim pieces, I had to remove the long silver piece across the dash from the passenger side to the on/off button, the trim around the small center screen, and the four screws that hold in the knobs and buttons before being able to get the top trim piece off that allows access to the shifter. A trim tool and lots of patience helps..... At least I have a set of trim tools.
Thanks @jmyer72 for posting your OP with parts links ??
Yep on XLT. I figured this out half way into my install. I followed a higher trim video tutorial and was scratching my head on how to get the shifter trim out from under the AC controls. I ended up having to watch a 2021 ICE video on how to replace radio to get the multiple dash trim pieces off safely. Thanks for your comment to point me in the right direction.
21st Century Truck
Martin
Anyone have recommendation on trim tools to use for this? I also have an XLT so I wanted to get some proper tools to pop off the various pieces.
Just the basic small trim lever is all You need (all I needed) on the XLT.
ENDianDigital
Ian
Hey, yeah sorry, I totally missed that front right bolt hole in your original pics. Yeah, that would totally be sufficient from what I've seen.
My mistake; sorry for the confusion!
CRAIGC540
Craig
Moreno valley
Technician
Has anyone had any problems accidentally shifting into a gear while moving,
Is that even possible or is the dail locked in place while in motion?
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
I swapped out my shifter today, many thanks to @ditkafan1985 for creating the custom base and providing encouragement that even a rookie like me could carry out the change. Here are some details that others may find interesting, as when I was considering doing the swap myself I wanted all of the info I could find.
I started getting the "powertrain malfunction" notice on 4/19/25 and it was there for a few days then disappeared for a week or two and I thought things were good as if an OTA update somewhere had suppressed the warnings -- but nope, it came back and became more frequent and over the last few days it was an everyday thing.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_0153
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_0179
For guidance, I used this video which was referenced here before, which was a big help to show that dealing with the trim pieces were the most difficult part of the job, and that the actual swap of the component was the easy part:
However, one thing I found is that the above video was made while working on an upper trim Lightning with the large screen, and that the trim pieces on my XLT were definitely different.
The side trim pieces came off pretty easily, but then the removal of the lower base trim was definitely more difficult than in the above video and once I got it out I cut off some tabs to make re-installation possible (I think without that, the trim piece that surrounds the volume/tuner knobs on the XLT should have probably been removed).
Once I did get the base time piece off, I took a quick video of the "ducka ducka" sound that the shifter was making during its last breaths (and it was doing it whether the truck was on or off). It had done that 3-4 times over the past couple weeks and gently bumping the shifter more forward into park would make it stop, but this time after backing into the garage to do the work and putting the truck into park made the ducka ducka start again and this time it wouldn't stop. So it was very timely that I was replacing the shifter, as I've seen owner comments here and on reddit that their shifters were sending the improper signal to the truck and the truck wouldn't move at all. I wondered if I was getting closer to that happening to me, who knows. And yes the wrench light was on when I turned the truck off, it had been on steady for the past 3 days and sometimes would report that to the app and sometimes not, no idea why or why not.
As I noted above, once I got the base trim piece out I decided to cut off those tabs that connect underneath the dash, which was also mentioned in the replacement video above and I figured that the side trim pieces were going to hold the base time piece in just fine without those tabs that go directly under the dash.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_0181
It was kinda tough to get the side trim pieces back into place properly and I'm not sure they went in perfectly, as there's a bit of a gap on the right side -- unless maybe that was already there and I didn't notice?
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder Right_Trim_Ga
Anyway, here is a pic of the finished product. Yes I know that the pics show how dirty the interior can get with daily commuting (mine is almost 2hrs each way), but my priority was to get this swapped out and worry about stopping at the car wash & vac later. I'm also going to get a small round piece of rubber to act as a coaster and cover the bolt head in the cup holder of the printed base.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_0186
End result: truck started normally, and no more wrench light!
