Kyler721
Kyle
2023 F-150 Lightning
Cyber Security
Yes. The update that adds the toggles back has only been released to EA members. It does not show up in the latest FDRS pull of modules needing update. Hopefully it will in a few weeks. Until then I enabled it in Forscan some time ago, so I am not too worried.
Can youn detail what line of code you changed in FORScan to add the toggles back?
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
Kyler721
Kyle
Cyber Security
Kyler721
Kyle
Cyber Security
There may be more needed. But when I had BC 1.0 on my 2023 I enabled the BC 1.3 features with the following, granted I did have all of the latest module updates using FDRS though and had an active subscription to BC. YMMV.
The following added the toggles for BC 1.3. Note without the module updates, these won’t do anything or may not give the desired effect. In my case, since the dealer was unable to update modules without a recall, I had to do this myself with my personal FDRS setup. The point I am trying to make is that the Forscan updates don’t buy you much unless you have the proper module updates like IPMA. The good news is that for the most part they are easy to update, if you have the FDRS setup (cable, power supply, windows laptop).
Thanks for the lines of code. I’m taking my truck into the dealership to have them perform updates on all my modules as I have a list of ones needing updates from PTS. Hopefully that will get me blue cruise 1.4 and resolve my Apple CarPlay issues.
majorgearhead
Summerville, SC
You will get BC 1.4 and if they apply the latest APIM you should not have to do the Forscan part. Good luck. If they are willing to do them all, tip/pay them well. It is rare that a dealership will do this without a recall.
majorgearhead
Summerville, SC
Sorry what was posted before was never meant to be public and is nothing you will need to use. Just have the dealership update your modules and with the latest APIM you should have the needed toggles.
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
I installed the OEM trailer brake using FDRS this evening while I was updating other modules. I had a TRM update showing before I removed the old module. It was still showing after the trailer brake configuration completed. When I attempted to run the update it failed. I cleared the DTCs and tried a couple of more times, all of which failed. Is this due to the update being for the old module and not matching the new module, or could there be something else going on? The trailer brake appears to work, it started raining and I was unable to test it with a trailer this evening.
I'm also having an issue with SiriusXM not showing song title or artists after applying the ACM update. Any ideas on how to resolve this?
The database on FDRS most likely has a different p/n for the TRM and therefore is trying to load different files. I can't say with 100% certainty, but I don't think you can update it with FDRS.
As far as the ACM issue goes, if your FDRS is still active, try running a PMI on the ACM and when FDRS asks if it is the original module, select no. I have your VIN and I pulled the codes your truck is reporting and there are no codes in either the TRM or ACM, so hard to say what is going on.
priceb
Price
College Instructor
Thank you for your reply. I still have a day left on my license so I will try the PMI on the ACM this evening. As far as the TRM, it sounds like there is nothing to update.
priceb
Price
College Instructor
Thank you for making the connection that others were having issues this morning. I thought that they were working after the update last night, but when I got in the truck this morning they were gone. I wonder if it is just a coincidence.
That is mighty strange, but as long as it is fixed, all good in the hood.
priceb
Price
College Instructor
I will wait until later this evening to do the PMI on the ACM. If it is something on Sirius's end, I doubt anything I do will resolve it.
priceb
Price
College Instructor
I can confirm the Sirius issue resolved itself. Thanks for your assistance.
