LightningLover
Silver Spring, MD
Mustang Mach E (E4X), F-150 Lightning (Lariat ER)
Twice now I have heard @tommolog state that Ford has increased the torque setting on the Ford Charge Station Pro. I received my FCSP in July 2022 and every copy of the installation I can find online, including from Ford's website, has the same torque settings as my instructions:
A/L1, B/N 60 in-lbs
Earth 35 in-lbs
DC+, DC- 35 in-lbs
RS-485 Terminals 3 in-lbs
Are there different torque instructions out there somewhere?
https://content.fordpro.com/content...ord-Charge-Station-Pro-Installation-Guide.pdf
mattis
mattis
I have received my Ford Charge Station Pro and I snapped some photos of it being unboxed and I created a .pdf of the install guide that came with it. I plan on doing the install tomorrow and will share how that goes when it's completed. The install guide came with a separate cover that supercedes the cover that is on the guide itself. You can see it explained in all caps on the bottom of the cover. I only included the corrected cover. The original cover that is on the guide has a sticker that contains the Charge Station ID, MAC address and Access Code to the charger so it will obviously be different for each charger. I included all the documentation that is in the box. Enjoy!
Edited to add a photo of the charger mount plate that was under all that foam packing.
The AC charging is done via CCS1 connector?
CCS1 is a combo connector: AC and DCFC.
On the FCSP, the DC pins are reserved for use with the Home Integration System / Whole Home Backup System.
MrCoolDu4
Chicago, IL US
2023 Ford F150 Lightning Platinum
I installed the Pro charger and it's working well. The only issue I have is connecting it to the app.
Wait a few days, out of the blue you might find that it has integrated and you'll be able to see the FCSP status, settings and charging history.
