Is there a way to make all four windows roll down with your key fob?
danchristy
danchristy
Dan
Melbourne FL
F-150 Lighting
Audio Video Lighting Engineer
Ford has never enabled the back windows due to child safety protection
You can definitely do the front windows through FORSCAN, it's actually pretty fun to do and then once you go down that rabbit hole there's lots of things you can do
What OBD scan tool “brand & Model” should I get it for the Ford F150 lightning 2023 to use with Forscan?
mrau
23 Lariat⚡ER
The OBDLink EX is an often recommened for use with FORSCAN.
Ford F-150 Lightning Is there a way to make all four windows roll down with your key fob? Screenshot 2024-11-01 at 11.05.27 AM
PJnc284
Garner, NC
Mongoose. Expensive but once you get to tinkering, you'll find yourself wanting more and installing FDRS before you know it. :cwl:
Danface
Dan
Central Mass
2023 Lightning XLT
Just gotta keep from bricking the rolling brick (that is the Lightning).
Jackdforme
Barry Allen: 2025 Ford F150 Lightning Flash
I believe no F-150 does all 4 windows, because the door control on the rear doors isn't capable of Global Windows.
Door control on rear doors lacks a proper position memory sensor for auto up/down. So only the 2 front can do global windows. Kind of just northern hemisphere windows tbh.
CircusCowboy
Is there a way to get your windows to roll down buy holding down the lock button from you key fob like the ICE F-150
You can do it now without forescan, but it will only roll down the front windows, hit unlock twice and hold it down on the 2nd push. Lock twice to put them back up.
davehu
hot springs, AR
would be a great option. When your in the house and you hear it start raining it would be wonderful to pick up your phone and close the windows with a touch of a button instead of doing the 40 yard dash through the parking lot.
Why do you leave your windows open?
Why do you have a parking lot at your house?
Is your driveway really 40 yards long?
astrand1
Alex
Studio truck driver
I know there are other threads on this, but it still blows my mind that Ford missed this being available out of the box when it’s on the MME and ICE F150s. It seems like they went out of their way to muck this up on the lightning.
Negative. Not available on the ice f150.
davehu
hot springs, AR
My dog goes with me everywhere so when I go into a store I leave the windows open 6-10 inches. come to think of it, it would be great if one command would close the sunroof too! (Summer time is hot so I just leave the truck running with the AC on.)
Jackdforme
My windows can go up. The front ones only. But I did the forscan changes to allow global windows which also enabled them up.
RLXXI
3rd rock
Automotive Technician
RLXXI
3rd rock
Do you remember what module and changes you made in Forscan? Or was it a menu item?
Jackdforme
1. BCM Module:
Modify 726-17-01 to 0101 0101 014 or 014B according to a forum post on F150LightningForum.com.
Modify 726-17-02 to 0101 0101 014B according to a forum post on F150LightningForum.com.
Modify 726-30-01 to 0101 0000 0060.
2. DDM Module:
Locate 740-05-01 and ensure the first digit is D.
If it doesn't start with D, replace the first digit with D.
3. PDM Module:
Locate 741-05-01 and ensure the first digit is D.
RLXXI
3rd rock
1. BCM Module:
2. DDM Module:
3. PDM Module:
Got a link to that post?
