I charged to 100% and my Lightning said 379 miles!
Yep. That’s pretty much what I was saying. We are programmed and our brain says you got 319 miles on the meter then you got 319 miles of travel depending on what type of lead foot you have. Gotta learn to disregard that I guess
I don't understand this mentality, it was exactly the same with ICE vehicles. If I drove 100 miles in my PowerBoost F-150 I could get 24-25 MPG. With a 30 gallon tank, it would tell me at fill up that it estimated 750 miles on the tank.
If I then drive around a town, like let's say I was driving that 100 miles to a destination, and was averaging 18 MPG, my DTE would drop like a rock. From 750 to 500 just from me driving 20 miles and getting lower efficiency.
It's essentially the same as people complain about with the EVs. The major difference is the DTE in an EV takes more factors into account than ICE vehicles typically have, like outside temp. But outside temp impacted your ICE vehicle as well, you just had to drive and actually get the lower mileage for it to show on the DTE.
All that is to say, I don't know why people really trusted the DTE on ICE vehicles either. It was always just an estimate, and an estimate based on history. You only took it as fact because nobody ever actually drives it from full to complete empty and compares it to what it said at the start. Also since you were dealing with large numbers (750 or whatever) for the DTE, you didn't notice if it dropped to 500 as much as you notice 300 to 150.
Yes they're the same, but no they're not the same...
The differences are, IMO:
- immediacy of impact of change in temperature
- availability of refueling and the smaller distance between stops on EV
The impact of cold on the EV is quicker than the impact on the ICE vehicle also, partly because the heater has such a large impact.
Worse case, with a gas vehicle, I stop, add some "high priced" fuel to get to the next refueling stop with cheaper prices, and move on. With the EV, in places, I have X miles to go. If I then hit colder temps and a headwind, I'm forced to slow to make it.
There are also locations that go down, and can dramatically impact a trip, requiring dramatic slowing, or rerouting, assuming you find it in time.
jimfigler
Orchard park, NY
I rarely charge to 100%. I have it set to 80% standard, but I was planning on a long trip, so I topped it full. (I also read it’s good for the battery to do this from time to time.)
When I started my trip in the morning, I was surprised to see my truck say I had 379 miles of range! In the past, when I have charged to 100%, I have seen it say up to 340 miles.
Has something changed with the way the battery calculates range?
I use a Ford Pro Charging station and have an extended range battery.
All this means is that its summer and you drive very slow
jimfigler
Orchard park, NY
My ICE vehicle said 408 miles when I filled it this weekend. Do I look at that number and care about it? No. All I look at is the gas gauge and fill when it's close to E. All we should look at is SoC
Yellow Buddy
Smart Ass
It’s just what people are used to, range anxiety. I get the reverse nowadays, I get range anxiety when I hop into an ICE vehicle.
I know where all the DCFCs and L2s are in the area I travel. And I know how to quickly plan, lookup, and estimate what I need on any of my EVs - across different brands.
Put me in a gas car? I’ll stop short with 1/4 of a tank to fill up or I’ll freak out when I see a sign that says no rest area for X miles.
Brent@ANParts
Diamond Sponsor
Brent
www.autonationparts.com
Ford Bronco
Marketing
I think for me, at least, the gas gauge always felt very consistent. I could more or less understand the rate at which my truck was burning gas, but with a lot of EVs it seems more erratic and just so much more sensitive.
Regardless, it's something that is constantly being improved upon and I look forward to a future with more and more charging stations, so that when you drop to 20% or even 10% you're not panicking and driving 10 below the limit.
Robert1380
Robert
2025 Ford F-150 Lightning Platinum
Retired law enforcement
I agree with you. I’m still learning the characteristics of my truck and that’s gonna take awhile.
We recently took a short 300 mile trip and on the return leg, I had charged to 90% prior to heading out thru the desert. In less than 20 miles my truck had a drastic drop to 53% and had amber colored charge and miles till zero staring at me. Would have been fine accept there was literally no charging locations for 130 miles. That definitely got my attention as it was 114 degrees and the cell service thru parts of the desert are sketchy.
jjupi91897
I observed the same thing with my Lariat ER. I believe it has to do with the warmer weather. During cold weather, I get the exact opposite effect.
Deleted member 21405
Guest
It’s mind boggling how people always take the bait to posts like the original one. Over and over and over again
lipnorth
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
Just charged again to 100% and only 349!
Rip
Rip
Southwest Harbor, ME
2024 Lightning Platinum
Quality Consultant
It didn't drop that fast. I don't think I actually get 379 but it didn't drop that quick either (I expected it too). I was surprised.
I've been surprised lately that I get over 300 (usually around 320-330). I chalked it up to warmer weather. I bought my Lightning in December in Maine, and in winter usually only see around 240-260 after a full charge.
22legit2quit
2024 Ford Lightning Flash ER
This is one of those that you want to see on yours but realize that some people still believe in Santa Claus too. It’s all about driving habits and ambient temp, nothing based in reality unless you are driving only city miles. Sorry.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
Get used to it. Mine does the same, 345, 348, 354, and it is 3 years old with ER battery. I know all the folks will tell you to drive it a bit and it will drop back down to normal. It will drop but not fast. I have done all kinds of scenarios, even getting it to the interstate rather quickly to monitor the drop. Those extra miles of range come handy, at least for me. Monitor and reply back. More observations will help the rest of us to compile info and compare ranges.
Good luck.
lipnorth
lipnorth
Connecticut
On my latest long trip, I was getting 320 miles to the charge. But maybe I drive like an old man.
