Can you activate PPO without having to keep the truck "running" the whole time?
dmd3home
Dan
Central Coast CA
2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
I am really tired of having to "start" my truck and leave it "running" all the time when using PPO....which could be for hours or even overnight. Everytime I have to start it, turn the headlights off, and shut down Android Auto (or the truck automatically steals my phone audio) and leave the screens running for hours....just to activate and keep my bed outlets. This just seems like way too many unnecessary steps.....and wasting my precious power on lighted screens. It would be soooo nice to just be able to push the button on the bed outlet module and have power (what's that button for then?). I think I saw other similar questions here and some thought that maybe this would be fixed in an OTA update. Is there a simpler way? Thanks.
EvilUser007
2024 Flash, 2015 Model S, 2017 MS
Yeah, you need to keep a load of at least 100W plugged in or else it thinks the system is not in use so it shuts it off. It's been discussed here before to get a 110v timer and plug in a small 100w heater. You program the timer to come on for a couple seconds every 5 minutes to keep ppo alive with truck off.
I did it and it worked perfectly so I can use my dash cam system as surveillance cameras.
These are the two item's I use.
https://www.amazon.com/dp/B09BZ8LQFB?ref=ppx_yo2ov_dt_b_fed_asin_title
https://www.amazon.com/dp/B0BTLMNFB1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Since the heater is only cycled on for 2 seconds, it never gets hot enough to harm anything. I plug it in the outlet on the dash and let the timer and fan slide into the side pocket on the console.
Genius. But wouldn't it be better to have the heater in the bed just in case the timer gets spastic and keeps it on? Or is 100 watts not enough to worry about?
Edit: Your link is for a 200 watt heater
dmd3home
Dan
Central Coast CA
This is not what I'm talking about......I have plenty of load as I'm charging my other EVs from my truck. I'm just frustrated at how difficult it is to get PPO running in the first place. Why does the truck have to be "running"? Why do the screens have to be powered up?
When the truck is "running" all the time, it's always trying to connect to my phone and steal my phone audio......I have to turn off my Bluetooth and wifi. I have to turn the headlights to OFF. Why? Why not just allow PPO to run independently with the truck "OFF"?
GoodSam
Good
occupying space
PreservedSwine
Fort Myers
2023 Lightning
Obviously whatever ev your charging isn't enough load to keep the PPO activated, with the mod posted you DON'T have to leave the truck running all the time. Just toggle the slider on screen to keep it on with truck off.
im not sure exactly how you're able to to energize the bed outlets with the truck off. Ignore the load minimum for now please.
How are you energizing the bed outlets without having the truck "on?"
Like the OP, I would like to run PPO and not have the dash on.
Thanks
strmwzrd
Nebo, NC
F-150 Lightning Lariat
I thought this was fixed for newer Lightnings but certainly not for my 2023. You are so right, it makes no sense to have the truck "on" for all the reasons you stated just to use PPO. I once left my truck "on" for 4 days after an extended power outage. @Ford Motor Company please fix this issue.
PreservedSwine
Fort Myers
2023 Lightning
No. On the same screen there's a slider that says to keep the PPO on with truck off.
Do you have the 15" or 12" screen?
thanks again
EDIT:
I have no such option on my 12". Just a slider to set when it shuts the outlets off at a miles to empty setting. The outlets are only energized with my truck "on"
Kind of a bummer. The routine of shutting down headlights/AC/radio/carplay/mainscreen- and no way shut down or even dim the dash is a bit cumbersome. Encouraging you're able to pull it off, perhaps someday I'll get that feature.
HOTAS
Airbus Pilot
Just push the unlock button on your remote, (and within 1 min.) reach into The bed, and push the pro power button. All outlets are ready to go.
No need to start the truck. That’s how it works in my ‘24.
And it activates the interior outlets too.
Ford F-150 Lightning Can you activate PPO without having to keep the truck "running" the whole time? IMG_0429
Ford F-150 Lightning Can you activate PPO without having to keep the truck "running" the whole time? IMG_0428
Pre-2024s do not yet have the ability to run PPO without the vehicle running.
Ford added this to later models, they noted in an article it would come to the earlier models in a SW release. They have never delivered.
HOTAS
Airbus Pilot
Pre-2025s do not yet have the ability to run PPO without the vehicle running (not positive on 2024s, too late to verify).
Lol, it works on my ‘24. Reference included.
So much confusion here.
PPO works for all years with no minimum load required if the truck is turned on.
Starting with 2024, there is a Sync option to use PPO with the truck off. In this mode, there is a minimum load required.
It really helps when folks include model year on their vehicle profiles, we have an apples, oranges & bananas conversation in this thread.
dmd3home
Dan
Central Coast CA
thanks again
EDIT:
Exactly! That's what I'm saying!
I don't know how this moved to "keeping" PPO running and a sufficient load to do so (my load is 4kW). My complaint is having all the accessories and screens running while using PPO. Is someone suggesting there's a mod or update that fixes this? Mine's a 23 pro model.
