Rotary Shifter Part Numbers
UncleTony
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I have a -U on order that I should be able to install the 2nd week of August. Fingers crossed that it works at all, I will let you know whether it is motorized or not.
Did you get yours installed? This is the motorized one I just ordered. I should have it Saturday. LX6Z-7P155-U
Lawrence
25 F150 Lightning Lariat
Instrument Technician
I’m compiling a verified list of Ford rotary shifter part numbers.
The current working theory is that part numbers starting with LX6P or LX6Z typically refer to motorized rotary shifters. These are commonly used in 2020–2022 Escape, Bronco Sport, and others.
I’m hoping to collect real-world confirmations so we can build a reliable cross-reference list for retrofits and replacements.
If you’ve used one of these parts, please reply with the following:
  1. Part number (example: LX6P-7P155-EH)
  2. What vehicle it came from (year and model)
  3. Whether it is confirmed to be motorized (yes/no)
  4. Any other notes (source, behavior, fitment issues, etc.)
LX6P-7P155-XX believed to have the blue light in dial base (ring)
Motorized Rotary Shifters
These rotary shifters have a built-in motor that automatically rotates the knob into "Park" when the vehicle powers off.
Part NumberConfirmed ByNotes
LX6P-7P155-ED—Believed motorized
LX6P-7P155-EE@AjzrideConfirmed motorized
LX6P-7P155-EH@Drayday55Confirmed motorized, has “L” button
LX6P-7P155-HE@jmyer72Confirmed motorized, has “M” button
LX6P-7P155-HG@digitaldadConfirmed motorized
LX6P-14G395-AB@AjzrideConfirmed motorized
LX6P‑7P155‑AD@RobocopConfirmed Motorized
LX6Z-7P155-B—Believed motorized
LX6Z-7P155-M—Believed current motorized revision
LX6P-7P155-LE@Mike G @sstevetxConfirmed Motorized
LX6Z-7P155-U—Believed motorized
Non-Motorized Rotary Shifters
These do not auto-return to Park. Knob may rotate past Drive, depending on configuration.
PZ1P-7P155-AC@The WeathermanNon-motorized, has lit base
LJ9Z-7P155-D@farmtruckNon-motorized, from 2021 Mach‑E
NZ6P-7P155-AD@mr.MagooNon-motorized, Maverick
PZ1P-7P155-HC@mr.MagooNon-Motorized, Escape, has Ambient
NK4Z-7P155-D@mr.MagooE-Transit
Check out @Mike G 's install method here - This is the best way I have seen it done so far if you care about keeping all your clips intact.
Please add any others you’ve verified, or correct anything above if you’ve found otherwise. Once we gather enough data, I’ll update the first post with a full list of confirmed motorized part numbers.
Worth a read before ordering to make sure you get the updated part https://www.macheforum.com/site/thr...pressed-transmission-remains-in-park-p.21849/
Thanks in advance for contributing.
I just installed a LX6Z-7P155-U and it is not motorized
UncleTony
UncleTony
Tony
Interesting, that is the first one that breaks the pattern that was building. Also disappointing since I was looking forward to it. Did you buy it new?
Shmoe
2024 F-150 Lightning Lariat, 2025 Rivian R1S, Sold-2020 Tesla Model 3 SR+
Lawrence
Yes sir from a ford dealer in south Texas. Installed yesterday. When I open the door the indication change but did not move. I will check again tomorrow
j1francisco
2018 Ford Raptor 2023 Ford Lightning
that’s a bummer! I just installed the same one this afternoon and confirming mine is motorized. Maybe the wrong model was shipped?
I did however get an electrical fault upon install. Luckily a battery reset was able to clear the fault.
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_5027
j1francisco
This is the error that popped up. Gave me a quick scare but everything seems to be operating normal. I was swapping the shifter while the truck was on so my fault there.
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_5029
Shmoe
I see alot of them on eBay ship from China and am wondering if there are some counterfeits out there and maybe OP saying it isn't motorized is just mistaken since he said the indicator did change.
UncleTony
UncleTony
Tony
He said he got it from a dealership. Mine is supposed to be here soon, so ill add my experience with it when I can.
Shmoe
I saw that, I'm figuring it actually is since he said the indicator moved.
j1francisco
That could be possible. Bought mine from eBay and it for sure came from China based on outer packaging.
Shmoe
I think everyone thinks you meant you bought the shifter new at a dealer, not the car. I think that settles that confusion.
Does the dial move freely around in a 360?
This is the same rotary GEAR for the 2020 Ford Escape my son just bought... what will the middle 'L' button do for the LIGHTNING? Change the Drive Mode, maybe?
Serves as the neutral hold button.
UncleTony
UncleTony
Tony
I received my LX6Z-7P155-U today and it was just another PZ1P-7P155-AC (Same Seller). So I am thinking the LX6Z's are non motorized and the LX6P's are the motorized ones. The seller says both part numbers have the same function.
