Ajzride
Alan
Houston
Eng
I will say, going back to the video i wish i had continued to watch to see the correction in the video, i would recommend going in the video on YouTube and cut that section out to assure another goofball like me doesnt make that same mistake. I wish the plugs were different to make it more obvious, because it easily goes into both plugs on my box, in the video you mentioned it doesn't fit.
I could not figure out how to change the video. The only option is to delete it and the create a new video. Perhaps I should just delete it now that i have a second video up.
RyZac
Owen
2023 ER Lariat w/Max Tow; 2021 LR Model Y w/ Boost
My 23 Lariat ER got BC 1.4 yesterday. Of course I haven't removed the Comma to see how it behaves. Lol
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Its nothing to write home about. Its a bit more stable and drops out less. Other than that, you gain automatic lane change on blinker.
Reactions: EVO
PJnc284
Garner, NC
pfft. I've had it since last October and still bought a comma. Have another 2.5yrs left of my trial too.
UncleTony
Tony
I have until 05/22/2027 on mine.
RyZac
Owen
Comma has been working great on bp4.0. The only notification I get is a " Lane-Keeping System OFF" when I first enable the comma. Hit OK once and enjoy the hands free after that.
Reactions: EVO
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
Finally got my Comma with bp4.0 to work in my 2022 lightning Lariat. This is the cable that made it happen!
Ford F-150 Lightning Comma AI self driver assistant IMG_1402
campalex24
Alex
2024 Ford Lightning Flash
Hospistalist
Then I would agree that the comma seems to be defective. You can always try your thunderbolt cables for good measure. They should operate the same, as they are the same as 3.2 gen 2x2 internally (In this use anyways).
Edit - Disregard the TB suggestion, I see that you already tried that earlier on.
@UncleTony @Ajzride
Wanted to let ya know the knew one showed up, plugged it in with the custom harness I had ordered (thank you!) and it immediately worked, without problems, so it would seem it was the other device! Thank you immensely for helping me work through troubleshooting so I didn't just give up on it!
Ajzride
Alan
Houston
Eng
@UncleTony @Ajzride
Glad it was resolved. When you send the broke one back, please put a big sticky note inside the box tell them not to resell it without repair.
UncleTony
Tony
@UncleTony @Ajzride
Anytime, I'm not going to pass the blame to protect the adapter. Stuff happens and sometimes bad ones make it out. Glad to hear that you are up and running.
EVO
Randy
Leavenworth, Kansas
2024 lightning flash
electrician
Comma announced an update. Does this change anything for us?
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
If anyone is moving from the harness extension to the coupler, I could use an extension for testing. If you haven't ordered yet, I can give you a discount on the coupler.
I have an old one that has an intermittent fault. Works 90% of the time
UncleTony
Tony
Is it an extension or the modded harness? I was hoping for the extension so It would be easier to pull in and out.
