K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
Keep in mind that if the door is open enough for the FCSP cable to not be pinched, it will easily be open enough to allow mice into the garage unless you come up with a spacer to block that.You know you should be able to adjust the stop of the door up and down. So if the door is tight enough that the cable makes it reverse just adjust it up a smidge and then It should be fine.
