MICE IN THE FRUNK!!
OpenMinded150
Ethan
Northern NY
2023 ER Lariat Lightning
Renewal by Anderson
Hey all. Not sure if this has come up. But I recently have been greeted by mice inside my frunk covering all my belongings in some lovely poop and pee. Turns out they are getting in through the 12v battery cover. There is a piece of foam at the bottom and its not enough to keep them out. There is no food in my frunk just some cloth cases they can chew on. Just a warning for anyone that hasn’t come across this yet.
Ford F-150 Lightning MICE IN THE FRUNK!! imag
Ford F-150 Lightning MICE IN THE FRUNK!! IMG_0066
Ford F-150 Lightning MICE IN THE FRUNK!! IMG_0063
Deleted member 12322
Guest
I think this might be more common than people think. I've heard of / seen cats seek shelter in vehicles because they're warm or provide shelter. From the Mices perspective your frunk is an awesome home impervious to rain and predators lol.
Wattsgas
MIke
Brinnon, WA
I am in a rural area and I have had them in the Frunk and by the Air intake into the cab. I have a peppermint oil soaked terry cloth in the the battery cover slot. Seems to be working at keeping them out. I also have a rag in my tonneau covered bed. Seems to be working. Critters also seem to like being on the top of the battery between the cab and the bed. Nice warm spot in the winter while it is charging.
Scorpio3d
SS/IBA car wash owner
https://www.f150lightningforum.com/forum/threads/charging-station-not-detected.22493/
You will want to do something to prevent, repel, stop them from getting in and chewing up your wires!
Ask me how I know😉⬆⬆⬆
Yellow Buddy
Smart Ass
My cats sleep up in the wheel well and somewhere in a frame cavity that I can't see....I have never had a mouse problem in my truck. Plenty of dead presents around it though.
if I was a mouse, the Frunk would be one of the best places I've ever stayed!
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
Soy based and "renewable" materials throughout the truck....of course rodents are going to prefer it. I'm surprised they haven't started chewing on the "ActiveX" seats yet.
Farafield
Kim
Vermont
Ford F150 Lightning Flash
I had one in the cab and then found it dead in the frunk. I put cab fresh sachets around and add balsamic vinegar for essential oil to them from time to time. Appreciate hearing about the spots where they’re getting in. Keep it up! Thanks!
Farafield
Kim
Vermont
*** Balsam fir essential oil!!! Not balsamic!!!
flux capacitor
2023 F-150 Lightning
I know mice and rats will chew on the wiring and eventually cause a short. I had that happen on a 2002 Grand Marquis I had. You need to do something to stop it like a mouse house trap. Nothing like a 400v short to wake you up next time you grab that door handle.
I <3 My Lightning
OP... Did you know they did a redesign on the 12v battery cover? Mine is a completely closed, no opening and no foam.
Mice will do what mice do best. Get into everything.
In the sub frunk I keep a thick piece of felt soaked with peppermint oil that I refresh every couple of months.
OpenMinded150
OpenMinded150
Ethan
Northern NY
Renewal by Anderson
I did not know that. Ford must have already figured it out. Thank you for letting me know!
21st Century Truck
Martin
I use these devices on my Lightning and had them on my previous two Fords.
https://www.amazon.com/
Loraffe Under Hood Rodent Repellent for Car Engines, 12V 24V Ultrasonic Mouse Deterrent with LED Strobe Lights – Mice and Rat Repeller for Truck, RV, Vehicle Engine Protection, Pack of 2
On the Lightning, I put it above and on the driver's side of the 12V battery in the large space behind the upper frunk wall.
This gizmo emits random white strobes as well as some ultrasound above humans' hearing range.
Once mounted, they have worked for years on my Fusion Energi, then on my Mach E and now on my Lightning.
Correlation not being proof of causation, yet I haven't had mice tracks in my engine / motor spaces - but Sonny Boy did have some in his Fusion, with significant electrical wire damage. Obviously, we park often in the same general space.
Lytning
Georgia
Glad you caught that. Mice use balsamic for dressing on their wire insulation. 😂
Bestword57
2023 F-150 Lightning Lariat Ext. Range Enhanced Tow, 2013 Chevy Volt.
Network Administrator
Ugh, I know.
Cotton balls 7 drops peppermint oil on each placed in small receptacle (I use those little metal ingredient cups) and placed strategically around the truck - in frunk storage compartment, center console, under rear seat. -- no mice, ever! Renew 3 drops on each one every 6 mos. Oh, and I'd fix that foam thingy.
