Software Update to enable 2022-2023 truck to enable ProPower without starting?
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
Why are we not talking about how stupid it is to allow PPO to stay on with the vehicle off, but ONLY with a constant 90 watt draw?
If I'm actively clicking a setting to keep it on, then I want it on!
ryun
Earth
Those conversations are out there lol. There's been no official word from Ford as to why, but the popular user explanations are: safety reasons; to reduce calls to tech support saying their truck is losing more range with it on; to piss us off.
Ideally, Ford would just inform the user when enabling the option. Maybe even give them a time out slider with no load too.
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
So I just reached out to Jesse about this last night and successfully enabled this on my 2022. Here's how its done. Insane that this simple modification hasn't been delivered OTA to people who have supported the Lightning program the longest. Use forscan to make these changes in the APIM.
Jesse-Infotainment said:
As long as the truck is fully updated in FDRS you should be able to do this pretty easy
Set
7D0-10-03
XXXX XX2X XXxx
7D0-10-04
XXXC XXXX XXxx
tHAT SHOULD ENABLE THE SWITH to leave outlets on. That should be all you need to do.
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
In which module?
brirr76
Midwest / KC
2024 F150 Flash / 9.6kw + Max Tow - Midwest / KC
90W minimum actually. I have a 110v timer plugged into one of the outlets with a small personal 200W heater plugged into it. The timer turns the heater on for 2 secs every 5 mins to keep PPO from turning off so I can use my dash cams as surveillance while the truck is parked. Heater never stays on long enough to get hot.
Works great.
I like this idea. Do you think every 10 minutes for 2 seconds would still work? I need to keep my backseat-floor cooler on longer.
tnugentfl
palm coast, fl
APIM. Can't believe it took this long to flush that one out
Awesome! Thank you. The timer situation is a bit of a bummer though.
Careful in just putting in the circled values above. See this post for the proper values based on your actual config. Note you may also need updated modules.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
nice! thanks Jessie
Time to buy FDRS 2 day pass to get it to work
SBENKO
Steve
Blowing Rock, NC
2023 Ford Lightning Lariat
I think it's a no brainer: Unlimited access to our outlets would trigger more battery warranty replacements.
Ford Motor Company
Official Ford Account
F-150 Lightning
No updates to share right now. I'm trying to find out what the next "big" update package will include and when it is slated to roll out. All that to say, I can't confirm anything - but I'm hoping we make you (and others) very happy. :)
Ford Motor Company
F-150 Lightning
