Software Update to enable 2022-2023 truck to enable ProPower without starting?
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
I have RV and I am super frequent user of ProPower to power my RV on the wild.
Recently I learnt the newer truck can turn on ProPower without starting the truck
It definitely saves more percious battery since screen is off, and it ensures the HVAC is not ON, and motor rail is not on, more battery saving.
Is it possible now with older truck?
Altivec
No... I've been waiting for this for almost 2 years. I was told when buying the truck this would be coming to the 22's and 23's. There are also videos of Ford engineers stating the same thing. Still no update or any further communication of this update which has made many, including myself very upset. That's where we stand as of today.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
Would be nice if we could just turn on and manage PPO through the Ford Pass app.
Karlo
Karl
2024 F150 Lightning Flash
I don’t have that capability on my 2024 Flash. Had not even heard of it
Evans
Evans
F150 '23 Lightning Lariat
Then you can trickle charge your LVB with the truck off.
Athrun88
Toronto, Ontario, Canada
If I ever have to go camping or such, I'm planning on getting a solar generator with a couple expansion batteries and run things off that instead of PPO given this limitation. Then use either solar or PPO to charge the generator/batteries when needed.
21st Century Truck
Martin
All you have to do in that case is to turn off the 30-minute OFF timer in the Sync, and turn on SILENT MODE. The truck will silently and pretty invisibly "run" for days and days. You can lock it too while it's doing all this.
ryun
Earth
From the complaints I've seen of PPO while truck is off -- mainly needing to have a constant load >60W applied otherwise it shuts off -- it really isn't necessary. Turn off the main screen, turn off HVAC/radio, etc: You've got the same thing but without the 60W requirement.
RLXXI
S. E. Louisiana
Automotive Technician
Afaik it's new for the 25 year model. I have the capability in my 25 Flash to allow all outlets on with system off.
Ford F-150 Lightning Software Update to enable 2022-2023 truck to enable ProPower without starting? 25lightningppowithtruckoffscreen
RLXXI
S. E. Louisiana
90W minimum actually. I have a 110v timer plugged into one of the outlets with a small personal 200W heater plugged into it. The timer turns the heater on for 2 secs every 5 mins to keep PPO from turning off so I can use my dash cams as surveillance while the truck is parked. Heater never stays on long enough to get hot.
Works great.
Kakaratto
Nate
2024 Ford F-150 Lightning Flash
My 2024 Flash has this too. Is that slider not present in 2022-23s?
