"Vehicle in Battery Saver Mode" Please drive
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
Perhaps you had a depart time scheduled and didn’t turn it off? Maybe that was a factor?
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Retired surgeon & jet aircraft pilot, Active rancher
For what it’s worth, I’ve been repeatedly getting this message for the past few weeks. I posted it under another topic and got a variety of suggestions, none of which seemed to help. I brought it to the dealer yesterday. They said the battery was in good shape and they were unable to immediately determine the cause. I left the truck there and they said it would take a few days to work it out. Of course I will keep the forum posted.
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive IMG_9504
Mikerson
ID
2024 Mustang Mach-E GT, 2023 Lightning Lariat, 2001 E-250 Sportsmobile 4x4
Any update? I’m dealing with the “battery saver mode” in FordPass now.
htobin
Howard
Ovalo TX
They replaced what I believe is called the “battery control module “ which resolved the problem
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
In the past this message often had to do with a weak 12v battery, or with something left plugged into the truck.
Mikerson
ID
Yeah, that’s what I’m seeing here, but the truck seems to be stuck in battery saver even when it is on (not accessory mode), or have it on a slow L2 charge. Nothing plugged into truck. You would expect it to jump out of battery saver when the LVB gets above a certain voltage, right?
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
it's strange that the deep sleep started after just 2 weeks
Just a couple weeks ago, my truck went to sleep mode after only 12 hours or so after parking in my garage. I tried to turn climate on the next morning but it said that truck was in deep sleep and I would have to drive it to fix the error.
Grumpy2
23 F150 Pro SR
Yes. Try letting the truck "run" for 90 minutes or so, that is turn off the power down timer, leave a fob in it and see if your 12v battery issue stops, at least for awhile. There has been discussion about whether the LVB is charged while the truck is on a level 2 charger.
Mikerson
ID
I only had a short time to mess with it before work, but I can confirm from car scanner that plugging in L2 causes the battery voltage to jump up. I think it was sitting at 14.5 V. I will dig in further to a SOC value for LVB and see if that is perhaps what is triggering battery saver.
halfbakedenchilada
2024 Lariat ER
Yeah, but 6 weeks?
Yep, would have been fine. I just parked the truck once for two months, like any other car, and it was fine. Did not disconnect the 12V, although maybe I should have. When I got back to it, it started right up.
Mikerson
ID
After sitting in my garage unplugged for 10+ hours while I was at work. It’s sitting on with shutdown timer disabled now.
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive IMG_2991
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive IMG_2990
Mikerson
ID
After 2+ hours on, we seem to come out of battery saver. I don’t see much difference from when I turned it on, but that seems to have fixed it at least for now. Just to be clear, the 12.2 V in my previous post was before turning on. The LVB battery voltage jumped to about 13.35 immediately after turning on, but we didn’t drop out of battery saver for at least an hour and a half. Thanks for the encouragement to leave it on for longer. Now, how can I get the dealer to replace this under warranty… (2023, 12000 miles)
Ford F-150 Lightning "Vehicle in Battery Saver Mode" Please drive IMG_2992
