Charging Lightning from a generator
Mikerson
ID
2024 Mustang Mach-E GT, 2023 Lightning Lariat, 2001 E-250 Sportsmobile 4x4
That was largely not an option when I bought my Honda.
What about a conversion kit? You will get less power. Not sure of your specific needs.
Mike G
N. AL, USA
The Ford mobile charger is configured to accept 240v. If it was only a 120v charger you'd get smoke.
The dongle just tells it what amps to set. It doesn't configure the voltage of the charger. The +- prongs of the 120v dongle are routed to the same pins as the ++ prongs of the 240v dongle.
Whatever adapter you use for the 120V to 240V receptacle is in the same category as suicide cords. Such adapters can be found on Amazon where any dum-dum can buy them.
This works on the Ford mobile charger.
Now that my friends is 'out of the box' thinking....well done.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
Amazon sells generators (some are Westinghouse brand) that have 50 amp NEMA 14-50 240 volt outlets and are less than $1,500. In theory these would charge the truck to full overnight using the Ford charger cable. Question I have is: does the truck care if it's an invertor generator vs. traditional wave generator? Both are available but of course the inverter style is more expensive.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
I’ve been meaning to test my inverter generator with the Ford Mobile Connector. It has a NEMA 14-50 connection, but the running wattage is only 7200. I believe the connector only operates at 32 amps, but my gen can only manage 30.
I have a nema 1450 to L1430 adapter and my inverter generator only outputs 8750 peak 7200 constant. The ford adapter can take 32, but if the generator can't give it, the evse will take what it can get. I ran my generator for about an hour giving the truck 7kwh to the battery.
The Ford mobile charger supplied with Lightnings is limited to 30a at 240v. This is so that it can be used with Pro Power, which is limited to 30a output, to charge another EV. The 240v dongle will have a yellow sticker around the cord for 30a versions. The mobile charger supplied with the Mach-E is set to 32a.
And it's not correct that "the evse will take what it can get." It will not throttle. It will try to pull what it's set for (e.g. 30a). If the source (e.g. generator) cannot supply that much it will trip the breaker at the source.
The EVSE will throttle it's output to the EV based on the current the EV requests. If the EV only asks for, say, 20a, that's what the charger will output.
Ok so you've tried it? That seems to make sense, id think the dongle would tell the charger both amperage and voltage, but if it's dumb, I guess that'd be a cool way to double your watts if you had a small 240 volt outlet for a compressor or air-conditioner.
I personally have not tried it but I have seen enough reports of it from many different people and sources that I'm confident it will work. And from an electrical perspective it makes sense. The charger is 240v capable and can accept either opposite phase voltage (-120v) or neutral (0v) from one input while receiving +120v from the other. The dongles are just different shape plugs and have a chip that the charger senses to set amperage.
I was looking for a way to boost charging speed when staying at an Airbnb with a dryer without having to get a mobile charger with selectable amps since 240v 30a is too much for a dryer circuit.
One thing to keep in mind if you do the 240v with 120v dongle is to make sure any extension cord you use is beefy enough. 2.8kw will generate more heat in the cord and plugs than 1.4kw.
jwrezz
1996 Ford Explorer, 2006 Subaru Outback Sedan, 2024 Ford F150 Lightning
Teacher/Firefighter
You can derate for the mobile charger on 2025 models on screen and in app . Before I got my FCSP installed I had to charge using my dryer outlet and had to drop it from 48A to 27A so it wouldn't trip the breaker.
I can't believe I said that. That's what breakers are for! Same line of thinking tho, that's why I'd think the mobile charger would not allow 240 thru the 120 dongle. Infact, it will allow 240, but limit it to the 12amp 120v max. Why is it that it can limit the amperage, but not the voltage?
My Predator generator is "8750 peak", but even tho it has a L14-30 outlet, it says "7000 continuous". It ran my mobile charger fine for over an hour. I guess FMC isn't 32 amps, but even 30 amps is more than 7000 watts. I'm proud of that little generator!
jwrezz
Teacher/Firefighter
OP, you can use a propane generator and spare yourself the gasoline troubles. Propane does not go bad like gasoline will. Also the expensive ethanol free gas claims to be pretty long lasting. I have found a generator with an inverter to be more reliable in powering the Ford mobile charger.
Don't dual/tri fuel generators produce their max wattage on gasoline, and less for propane, and even less for natural gas?
RLXXI
3rd rock
Automotive Technician
The big one I have is rated for 18k on propane, 17k on NG.
jwrezz
Teacher/Firefighter
Does it run on gasoline too? If it does I'd bet it's closer to a 20k generator. I know gasoline has more power density than propane, and propane is higher than NG.
RLXXI
3rd rock
Ng and propane only. My backup generator has a trifuel carb on it for all three gasses.
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
My generator runs pretty infrequently so any gasoline would probably go bad. I don't want to need my generator and not be able to start it because gas went bad. Propane does not go bad. Yes, propane delivers slightly less power, but the power delivery from a gas generator with bad gas is zero.
RLXXI
3rd rock
Amen to that. I hated keeping gas in the garage. Propane tanks always around for the grill and turkey fryer anyway so I put a tri fuel carb kit on my little Gen. Only gas in the garage now is in my bike.
Shouldn't the evse tell it's got the 120v dongle and only accept a suitable source? I'm sure there are plug adapters out there just as there are suicide cords for generator inlets, but I wouldn't think it would work.
Good bet that would work.
Yes, it works. Addressed in several other threads.
K6CCC
K6CCC
Glendora, Calif.
Your math is off. The Ford Mobile Charge Cord that comes with the Lightning will take 30 (not 32), so 30 x 240 V is 7.2KW - which is within the limit for your generator. If the MCC attempts to draw more than the generator can deliver, most likely the voltage will drop which will result in less power. That's not a good way to regulate the power draw. Also, if the generator is capable of 8750 watts it will attempt to deliver up to that much and most likely will overheat or just fail after a while.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
I did a test - the moble charger that came with the truck using the 2P-50A plug adapter charged the truck at 7.5kW per the truck charging display.
I put a meter on the power source , it was 241 Volts, 32 Amps which is 7.7kW but the truck will see a bit less after losses, so it makes sense.
Mikerson
ID
I don’t disagree with having a beefy cord, but heating is based on current, not power (Joule’s Law). 11 A at 120 V produces the same heat as 11A at 240 V. This is precisely the reason why we want higher voltage circuits…higher power without the extra current (more heat). For a given wire of course.
