Pro Trailer Hitch Assist via OTA update for MY22?
theaustinite
Ben
That seems correct to me too. Make sure any DTCs are cleared for the reverse brake assist, before trying also.
I made changes last night and it didn’t work, so I changed things back. Then my reverse brake assist didn’t work until I cleared the DTCs. I’m wondering if I had cleared them, then tried the hitch assist if it would have worked correctly.
I will try again tonight.
Ford Motor Company
Official Ford Account
F-150 Lightning
In this post @RickLightning says he got Pro Trailer Hitch Assist (aka Auto Hitch) on his 2022 after an update.
I just checked my 2022 and when I press the ProTrailer button, I get asked if a trailer is connected and when I answer no, it seems as if Pro Trailer HItch Assist wants to start. It was dark so I got a message it was too dark for the feature to work. I'll try again in the daylight.
Regarding the FORScan values shown above be careful; since they are for an Ice truck. Here are the values for my 2022. You need TowTech for this feature to work I believe:
706-01-01 xxxx-xx*x-xx - was originally a 1 but an update changed it to 5 late last year.
7D0-01-03 xxxx-xx*x-xx trucks w/o TowTech have A, with TT have B
760-03-01 xx*x-xx trucks w/o TowTech have 9, with TT have D
The values above also apply to 23-24 MY Lightnings that have the feature. I imagine you might also need an IPMA and ABS update from the original stock.
theaustinite
Ben
So I changed my 706-01–01 xxxx-xx1x-xx from a 1 to a 5. Everything else matched.
All updates except the latest BCM I completed in August.
When I press the pro trailer button I get asked if a trailer is connected, I say no, and it says Pro Trailer Hitch Assist is not available. With an orange bar across the lower part of the camera.
Ford F-150 Lightning Pro Trailer Hitch Assist via OTA update for MY22? IMG_2764
Jesse-Infotainment
2024 F150 Lightning Platinum
Any time you write to the IPMa you have to drive straight for a few for it to relearn center. SO the likely hood of errors and RBA not available is high. Its best to drive it after anything is writen to IPMA to relearn center then try it
There is also a PCM change needed to make it fully functional.
7E0-163-04XXXXXXXX02E0
theaustinite
Ben
Thank you! I’ll give this a try
Jesse-Infotainment
May need to update the PCM also. I had figured out an issue a long while back with a PCM OTA ford was sending out. It was causing a wrench Icon to show up.
It was due them enabling the Auto hitch in the reconfigure of the OTA on trucks that didnt have it enabled.
So some PCM strategies for earlier trucks MAY not have it. So there could be a scenario that you need to update the PCM strategy to make it fully work.
theaustinite
Ben
I did ALL the updates available back in August. (Only missing BCM with WAL)
I made the above edit to PCM, rebooted it, and drove about 10 hwy miles. Lane centering and ACC all working fine. No RBA errors. Still coming up with same screen on hitch assist.
Will just leave it for a few days and try again.
So mine seems to work now that I have tried it in the daylight. I press ProTrailer button, say No to trailer attached and I get an Initializing message:
Ford F-150 Lightning Pro Trailer Hitch Assist via OTA update for MY22? 1762399494695-m9
I don't have a hitch nor a trailer so I get an error:
Ford F-150 Lightning Pro Trailer Hitch Assist via OTA update for MY22? 1762399549269-q4
I haven't made any FORScan changes. My value for 7E0-163-04 is 01, not 02. I see that 2022's have 01 and 2023's with TT have 02.
I may put my hitch ball on and go visit our Scout trailer to see what happens. Curious what other 22 owners with TowTech see if they press the button.
One other thought is to do a module reboot with FORScan.
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
After making the change you posted, mine seemed to work. I said no trailer, then it popped up a target that you had to aim the truck at the trailer you want to hook up and I guess once it recognizes it, it takes over. I dont have a trailer at my house or I would have tried, but I assume it was working as intended.
theaustinite
Ben
Still says not available for me….
KingStraasha
Kevin
Dayton, OH
2023 F-150 Lightning Lariat ER, Antimatter Blue
After matching the changes, Mine still says not available as well.
Odd that the two of you with 2023's don't have it. I thought it was a new feature for 2023's. Were you early builds? @theaustinite says he did not get the BCM or WAL update. Did you?
KingStraasha
Kevin
Dayton, OH
I do believe I received the BCM and WAL updates. The last two that I received are: SYNC-25.2.1.6.5 and the BC 1.4 update. If someone can check, my VIN is 1FTVW1EV7PWG*****.
Jesse-Infotainment
Send me last of the vin
