Enabling charge speed on dash.
digitaldad
ABQ
2023 Lariat ER MaxTow
is there any way to sideload for the powertrain modules? I would love to get my PPO with truck off and fully enable the advanced charging settings. I dont see a option to update them in forscan beta, and for some reason I never got 10.3 in EA.
I am unsure. Luckily, I updated all my modules via FDRS back in late September (a bit before the price increase).
astrand1
Alex
Studio truck driver
does anybody have a clean link to the beta forscan download? im trying to get everything lined up so i can do the firmware update for the ipc this weekend. someone post above a link for the beta version but it downloads as some weird notepad file not an exe. thanks!
astrand1
Alex
Studio truck driver
digitaldad
ABQ
Still the same download. See the picture. It’s not an exe. What is it?
That link works for me.
Try right-clicking on the link and "save as"?
The unconfirmed is when the download in browser is not completing....look at the top right and look for a notice asking you to "keep" file.
PJnc284
Garner, NC
yeah probably something with the browser not starting the download as that's the temp file.
digitaldad
ABQ
Yeah, the browser security prompts for downloads...I get it, but my elder parents have a tough time with them.
astrand1
Alex
Studio truck driver
Thank you! That worked. This is why I hate windows. So unintuitive. Now my next stupid windows question. How do I keep both the beta and regular versions for forscan? When I install the beta it replaces the regular version. So I renamed the beta then re installed regular and it still replaces the beta.
astrand1
Alex
Studio truck driver
2101 is due to the lower portion seatbelt config. You can load a complete 24 IPC as build file and write it.. it will clear the 2101..
here is an as build you can use
2024_IPC.ab
Is this file for a 24 lariat with max tow? Or does it not matter? I have a lariat with max tow so want to make sure I don’t fuck anything up. lol.
PJnc284
Garner, NC
I believe there are some subtle differences depending on your config. I got a trailer module dtc with either that one or another one so searched the dealers for an extended range with trailer brake and there weren't quite as many differences. I ended up just restoring my 23 backup over the 24 to keep from making a billion changes but you want to note of the values for 720-13-01/02 and 720-14-01 from the 24 and keep those the same or you will get an IPC code. Top row was the 24ab and the bottom was what my 23 had. Seems these are related to the seat belt nannies. Apparently you can change them after the fact though as mine are currently showing all 0's after following the manual procedure to disable the chimes. Either that or it didn't update those to the mother ship.
Ford F-150 Lightning Enabling charge speed on dash. 1762358791133-4m
digitaldad
ABQ
I have max tow as well. Nothing related to that in the IPC portion that I saw. I used that 115kb file yesterday.
When you go to upload/upgrade the IPC module, follow the boxes exactly as you see in the "Custom File Selection.png" picture.
After 4-6 hours (service procedure done), load all the 2024_ipc.ab file, do not write all just yet.
Edit your glare free and seat belt chime changes back to what you had before the upgrade (if you had these).
Then write all.
Check for any DTCs.
As @PJnc284 says, you can restore the 2023 too, I only had 4 settings to change so just edited before the write all.
astrand1
Alex
Studio truck driver
Ok so I’m ready with everything. Charger etc. I’m at this screen. Nobody that I have found has shown screen shots of how I tell forscan beta to upload the IPC firmware. As in where do I click to point it to the file I have?
Ford F-150 Lightning Enabling charge speed on dash. IMG_1740
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
There’s a screenshot in the files you downloaded. You have to choose custom on that screen.
astrand1
Alex
Studio truck driver
Thank you. I got it going. Wish me luck. Started at 10:10a we will see how long it goes. 😁
