True, but we are not really talking about emergency backup hereI would stay home if there is a major storm and power outage.
What year is your Lightning? When I turn on ProPower, I get a message that the shutdown timer is disabled.I do wish ford would come out with a software update for my 2022 so I didn't have to run my truck to use the Pro power and not have to turn off the auto 30 minute shutdown.
Mine is a 2022. I haven’t tried to power my home for awhile but I'd have to start my truck , to get the screen to appear then start Pro power then go to vehicle and turn off the shutdown timer.What year is your Lightning? When I turn on ProPower, I get a message that the shutdown timer is disabled.
And having to leave the truck on isn’t a big deal for me. Turn off the headlights and HVAC & move on.
Mine was like that originally, but after an update, turning on the bed receptacles now automatically disables the shutdown timer.Mine is a 2022. I haven’t tried to power my home for awhile but I'd have to start my truck , to get the screen to appear then start Pro power then go to vehicle and turn off the shutdown timer.
I'll have to check that out. I do wish they would just let me start Pro power without starting the truck. I guess the new ones don't require you to start the truck to run pro power.Mine was like that originally, but after an update, turning on the bed receptacles now automatically disables the shutdown timer.
Correct. But (there’s always a “but”) if the truck‘s not on, PPO will shutoff in 5 minutes if the load is less than 90 watts.I'll have to check that out. I do wish they would just let me start Pro power without starting the truck. I guess the new ones don't require you to start the truck to run pro power.
How do you start PRO POWER if the truck isn't on ?Correct. But (there’s always a “but”) if the truck‘s not on, PPO will shutoff in 5 minutes if the load is less than 90 watts.
I’m guessing it has to be started with the truck on, then you can shut the truck off. Since I have a 23, I don’t know for sure.How do you start PRO POWER if the truck isn't on ?
At least on the 2024 (don't know about others), if you push the ON button on the bed outlet panel within a minute of unlocking the truck, it will turn on the PPO to the bed.How do you start PRO POWER if the truck isn't on ?
