NEMA 6-20 (220V 20 amp) charging solution?
jdmackes
2023 F-150 Lightning Pro
I also got the J+ booster 2 and bought the 6-20 adapter. Used it for a month or so until the power company had my wall unit installed and now it is my mobile backup charger that I keep in the truck. It's a really solid unit and was recommended by Tom from State of Charge, so that was good enough for me.
The J+ is ETL listed. It’s a solid choice.
JMD359
One843657295470895!
22 F150 Lightning Lariat,2022 Toyota Rav4 Prime,2011 F350 6.2L
Mechanic
New owner, first time poster...
Just picked up my Lightning, and we are living in a rental house, so my ability to install a 50-amp circuit is limited... I'm currently using the Ford Mobile Charger on a 120 V outlet with the expected trickle of 3 miles of range per hour...
The house _does_ have 3 outlets near a garage door that are 220V 20 amp outlets (the NEMA 6-20 "T" style outlets)
Do any of you have experience with aftermarket chargers that occupy the "middle ground" between the 120V 20 amp and the 220V 50 amp options I have with the Ford Mobile Charger?
I'm asking my landlord if he'll go in 50/50 with me about installing a 50 amp circuit in the garage, but I'm not optimistic...
Thanks in advance!
That’s all I use for over 90% of my charging is a 16 amp 240 it easily meets all of my needs. It charges at 3.6 kW about three times faster than what you have now.. you can buy a really nice Schumacher on eBay for about 60 bucks brand new it also doubles as a 120. It has a much longer cord than the Ford mobile charger and the handle and connector is much heavier duty. The wiring is heavier and nicer.. I have run this thing hard for three years between my Toyota RAV4 prime and this truck. It’s never missed a beat., my Ford mobile charger was junk in eight months and I used it about 10 times that was it..this thing has a 28 foot cord it reaches so far here’s one , I’d buy this again in a heartbeat .
https://ebay.us/m/eQpAwh
Tom M
Bossier City, LA
2022 F-150 Lightning Lariat, 2025 VW ID.Buzz
Pilot, Instructor
The J+ Booster EVSE is nice, pretty expensive, portable, and supports NEMA 6-20.
Ford F-150 Lightning NEMA 6-20 (220V 20 amp) charging solution? 1764614481483-cn
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Thanks in advance!
I have two Schumacher 16 amp 240v chargers and they are amazing. Used them on both my Plug-in, my lighting in both 120 and 240 configurations.
You can pick them up new (open box) on EBay for around $75-$100.
Been using one now for 3.5 years without issue.
Markip
Barrie Ontario
2025 F150 Lightning xlt
Manager of Operations
Dewalt ev charger with interchange plugs and auto detect amps it can pull I have one with nema 14- 50 14-30 6_20 5-20 and 5-15 works great all the time
DEWALT 25 ft. cord, 32 Amp, 120-Volt/240-Volt AC 7.6 Kw, Weatherproof Level 2, Heavy-Duty Portable
Model # DXPAEV032|Store SKU # 1001872291
Markip
Barrie Ontario
Oh jeez I'm late to the party oops
