Slight Reduction In Acceleration. Has Anyone Else Experienced This Issue.
Maineiac12
Iowa
Ford can limit your speed. However you’ve presented zero evidence to show that your truck is slower…… Btw the power curve is the same for all drive modes, the main difference is throttle response.
And as soon as I invent time travel I will go back in time to test both my 23, which I no longer own, and my current 24 and update this thread.
ClevelandBeemer
You could do that, or you could test your current 2024 truck which you feel is slower. The expected 0 to 60 is a known quantity. Not sure why it’s so difficult.
RLXXI
3rd rock
Automotive Technician
Didn’t miss that at all. Again, going from sport to normal involuntarily or not doesn’t make the truck slower……
Let me see if I can simplify this so you understand, I was looking at the screen when the truck changed modes from sport to normal, are you with me so far? Ok just so we're clear, the truck changed from sport to normal with no input from me. Glad that's out of the way.
As far as power increase or loss, I never stated that, I stated exactly what the owners manual describes when changing modes, you should read it sometime and save us all a lot of time.
Edit: Here's a screen shot from the manual that explains the difference when you switch to sport mode. When you expect sport mode and get normal mode, you WILL feel the difference, don't need a dyno to figure that out. This is exactly what's happening to my truck, I can't speak for others but highly suspect this may be their issue, just sharing personal experience.
Ford F-150 Lightning Slight Reduction In Acceleration.   Has Anyone Else Experienced This Issue. sportmod
Maineiac12
Iowa
It’s difficult because the power on takeoff (the throw you back in your seat feeling) feels different in this truck vs my old one. I can’t make a comparison because I don’t have my old truck to test against. I could compare it against others but those won’t necessarily be the same comparison unless it’s the same model year and software level.
Had I test drove my new truck extensively prior to purchase I would have gone back and done some side by sides, but I bought out of state and since I already owned a Lightning, I did the deal without driving in advance of pickup. It is what it is.
I’m not sure why you’re white knighting so hard for Ford here. Manufacturers make small changes all the time from model year to model year. It’s absolutely plausible that small changes in throttle response were made. I’m simply adding another voice to the chorus of others who have noticed similar things.
ClevelandBeemer
Speaking of reading, you should read my comments to you. Nowhere do I question that the drive mode changed on its own, so not sure why you keep litigating it…..
However what I keep pointing out is there is NO change in available power between normal and sport. However your comment said when you noticed the change and switched back to sport you “felt the same power you felt from day 1.” I don’t know what you felt on day one but both modes deliver the same mount of power. What you’re feeling is a change in throttle mapping…
I’m not white knighting Ford. I’m asking for hard data because your claim has ton of opportunity for error. Again we know how fast 2022, 2023, 2024, and 2025 trucks are supposed to be. So why not validate your theory? It’s pretty easy to show your 2024 is slower than advertised.
I’ll throw this out as well, testing it improving that it’s slower than it should be is also something to bring to your service advisor when you do your warranty claim.
At one point I felt my S1000R was getting slower after a few years of ownership. It turns out, I just became used to the acceleration. As it still runs a faster 1/4 mile than advertised.
RLXXI
3rd rock
I have the distinct feeling we're discussing two different things within the same subject matter. Have to say in my case there is no missing power so much as it is misrouted power.
ClevelandBeemer
So I went back through the last page or two and I see where the potential misunderstanding is. I take it you’ve edited some of your comments after posting? I swear upon initial read, some of the context currently there was not present.
I’m in total agreement normal and sport absolutely feel different and it would be apparent if you were expecting one mode but were in another. This is also very much what the OP and Maineiac12 are likely feeling.
blb228
Brett
2024 Flash Agate Black
From personal experience - I have driven and drive in Sport Mode 99% of the time. For fun; I had initially gauged my 0-60mph time after purchasing in March of this year to see how close this '24 Flash was to the advertised 3.8 seconds. This was a pretty consistent 4.1-4.2 second 0-60mph times on a very slight downhill, but even grade. I tested this again yesterday several times and was getting consistent 4.6-4.7 second 0-60mph times. It was in fact colder outside yesterday than when I did this same 'test' in March/April.
ClevelandBeemer
This is good stuff right here! So a few things, you’re getting 4.1-4.2 0-60MPH because you’re likely calculating without the 1ft rollout that Ford utilizes. When you remove the 1ft rollout you get a 0-60MPH run in ~4.16 seconds. So in March you were dead on.
Now for your run yesterday, was the road wet or covered in salt? Was SoC > 80%? Given the temperatures was 100% power available in the gauge cluster? Finally was TC off? Colder temps will certainly impact your times but just curious if there were other mitigating factors.
Ford F-150 Lightning Slight Reduction In Acceleration.   Has Anyone Else Experienced This Issue. IMG_8235
sotek2345
Engineering Manager
Now for your run yesterday, was the road wet or covered in salt? Was SoC > 80%? Given the temperatures was 100% power available in the gauge cluster? Colder temps will certainly impact your times but just curious if there were other mitigating factors.
There is also the fact that the Ford numbers are on a prepped (high traction) surface. Traction control will and does pull power when you try to do a hard launch which will show up in the times and vary based on the amount of traction you have. Remember, even if it isn't cold enough to be impacting the battery or motors, cold tires have less traction! If you haven't yet turn it all the way off (press and hold) and then try a hard launch and see what happens. 4 wheel burn outs are fun!
ClevelandBeemer
100%. TC should always be off when doing benchmarking runs. That said Fords numbers can be replicated on a non-prepped surface.
I’m looking forward to the spring so I can get some runs at the track!
PreservedSwine
Fort Myers
2023 Lightning
Full disclosure: when I first saw this thread, I thought everybody was nuts.
Then I received a phantom update, and it definitely accelerates differently post update.
blb228
Brett
TC was ON for all tests thus far - I haven't practiced hard starts enough in this thing to do better than the existing TC on dead stop starts. Yes, 100% power was available - I had it plugged in prior to heading out. Road conditions and state of charge were the same (as close as possible in a test like this) [dry and cleanish] in both 'tests'.
I wouldn't be surprised if the update that has changed this for several does have something to do with traction control/power delivery changes from prior. (I've had my studdering/shuttering on acceleration change frequency's several different times from my ownership already-)
Feel free to pick apart the differences/potential differences from my experience. I realize the gear oil would be a little thicker and the air is more dense in the second set of tests...... I wouldn't think air temp would have THAT much of an influence on these motors..... but it sure did on my old Ford Taurus SHO's with the two different length intake runners!
ClevelandBeemer
Again, this is great stuff. It would be nice seeing a result with no TC just to remove that variable, but otherwise your process seems reasonable.
This leaves you with two outcomes:
1. Due to the cold temperatures, traction issues are slowing you down by about 0.5s.
2. You’re also impacted my this mystery update that has reduced power output/deployment.
Hopefully it’s option 1, that said I’ve had wet launches that were better in very wet conditions (see the screenshot below)….. That said, TC was fully off so it’s possible the TC power cut is being a bit aggressive for you. Ultimately that’s going to come down to temperature and road surface. If not comfortable disabling TC you could always do a 30 to 60 roll to remove the traction variable.
Ford F-150 Lightning Slight Reduction In Acceleration.   Has Anyone Else Experienced This Issue. IMG_8237
At the end of the day 1/4 mile is not a very good way to measure this effect. Not only is there the fact that most people dont have 1/4 mile times of their truck, traction will always be an issue, there is also the fact that 1/4 mile runs are easy to predict and if Ford was really trying to sneak in a stealth power cut could detect dead stop, no throttle to full throttle easily and sneak back the power.
What really needs to be done is to measure HVB current like the Mach-e guys did. Using OBD data we could see if maximum current during NOT-quarter mile runs is potentially higher on early, non-updated 22s and 23s than compared to 24s and 25s. This is a direct measurement of HOW ford would cut power.
A quick stab at the throttle earlier had current in my truck spiking at over 1200 amps but it was hardly a good test
