- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
I think you should report the acceleration issue even if it does not come back - it is definitely a safety issue. If you do that and bring it to the attention of Ford as well, if you were unable to stop the next time, at least there would be a record that would prove it was not your negligence that caused the accident.Yeah that's the only time the random acceleration has happened to me. If it happens again I most certainly will report it so that it's on record.
This issue could very well end up being the 12v battery I guess. But if so that's pretty terrible. 6 months and 4,400 miles isn't a very good lifespan for a battery, especially when I drive the truck several times each week.
It is somewhat ironic, but a lot of EVs have a problem with the 12v battery because they rely on so much more electronics I suppose. But you'd think with a HV battery with 98kWhs of energy, some of it could be used to keep the 12v topped off more effectively.
My 2012 Nissan Leaf 12v got depleted when I went on vacation soon after I got it because the charging timers were running, apparently that was enough draw to cause a problem when not driving for a couple weeks. It has been on a trickle charger ever since - still going strong 14 years later.
All 12v batteries will last a lot longer if kept at or near 100% state of charge, something I learned my first year in engineering school, so a trickle charger is a must have in my book. A lot cheaper than a new battery too.
The Lightnings' 12v battery maintaining strategy does not seem to be designed for long life of the 12v battery. Letting these AGM batteries get deeply discharged will shorten their lifespan. Some owners have reported measuring very high charging currents - when a 12v battery is allowed to get deeply discharged, recharging it without current limiting control will result in high currents, which are also not good for longevity.
There seem to be quite a few 12v battery warranty replacements reported here and elsewhere and that's no wonder with this design.
The solution is to keep the battery on a trickle charger with an AGM mode when idle, or plan on replacing the battery frequently. It will keep the AGM topped off without subjecting it to very high currents.
