I got Forscan just before the holidays and just got a chance to make some changes. Global window open/close was something I enabled. I can press the unlock once then a second time and hold about 3 seconds and the windows go down. I can't get them to go up. I assume its lock and then lock a second time and hold and the only thing that happens is locking. I have rechecked my changes and all looked ok except on the APIM 7D0-09-01 I put the E in the wrong place. I have fixed that and still no joy. I also have enabled GF headlights so my APIM 7D0-09-01 is 6117 CEA8 FABF. What am I missing?
Triple check your changes, especially the BCM.
You can also open Easy Mode for each module and confirm the lines for Global are enabled. When you change As-Built, it changes Easy Mode, and vice versa. (Easy Mode just interprets the As-Built data).
Did you go into Sync and enable the feature: Settings> Vehicle> Windows?
xwing
Okeana, OH
2023 F-150 Lightning
I just went out to test the glare free and it works great. I went through the menu and saw remote window open was enabled, but remote window close was not. I did not test again, but I'm sure that has to be it.
It's buried in the notes so I added that step and instructions for use to post 1:
After changes go into Sync (Settings> Vehicle> Windows) and enable Remote Open and/or Remote Close.
Open: press and hold the unlock button on your key fob for at least three seconds.
Close: press and hold the lock button on your key fob for at least three seconds.
Cancel Open/Close: Press the lock or unlock button again.
xwing
Okeana, OH
It's buried in the notes so I added that step to the post 1 instructions and also instructions for use:
Thanks for doing that. It will help someone else in the future I'm sure. Global Up Down was the first change I made. Before I did anything, I did a back up of all the modules. Its not too bad to use NotePad to read the back up file and compare. Global up down and Glare free change the same APIM "KEY". As a retired IT guy its a lot like doing edits on the Windows Registry.
PJnc284
Garner, NC
AsBuilt Explorer is good for comparing
CompulsiveCode - AsBuilt Explorer
norpan
Oscar
Oslo, Norway
2024 F150 Lightning, Lariat, Extended Range
Do anyone knows how to extend the maximum time of 30 minutes pre-heat? When there is a lot of snow and really cold (and the car is plugged in) I would love to sometimes be able to let it run for longer to melt the snow.
PJnc284
Garner, NC
Not sure there's away aside from just going out and starting it. That's a carryover from the ICE vehicles that Ford didn't update.
chriserx
Louisiana
do the forscan mod to disable the shutoff timer and start it manually as PJ suggested
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
If you do a departure time while it is plugged in, I believe it will condition the cabin and battery starting 90 minutes prior to the departure time depending on the ambient temperature. That should be more than enough time to defrost everything while doing it on house current.
norpan
Oscar
Oslo, Norway
Wow, thanks - I will definitely try that.
21st Century Truck
Martin
...and it is very easy to reengage the cabin preheat from the app, should the set cabin preheat be set for earlier than You actually get to use the truck. It's on the front webpage of the FordPass app.
We just came back from a trip to Newfoundland Canada and we used this function often... we tried to plug in overnight at the Level 2 ChargePoint stations which seem to be fairly plentiful in the Canadian Maritimes. Then, if we got our act together by, say, 10 A.M. and the truck cabin preheat had been set for 8 A.M., I or the Nephew would just click on the FordPass "CLIMATE / Reengage" (my word here, from memory) and the truck would restart the cabin preheat, pulling the juice from the ChargePoint L2 overnight cable.
A very useful feature in the hard Canadian cold. Hope this is helpful.
pookguy88
cars
so first time FORScan user here with a 2024 Lightning, I programmed the APIM to enable autofold mirrors, wrote the value and Sync rebooted and it said to stop then start the truck/ignition, I did both of those.
But now I'm worried because in the FORScan app (Windows) the disconnect (and connect) icon are gone, I just unplugged the ODBLink cable... is that bad?
Everything seems to work though... anyone know what I'm talking about?
Once the values are written, you are good. Next time exit Programming mode (the Stop button at the bottom) and you'll see the disconnect and connect icons again. But no harm that you didn't click disconnect before unplugging.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1768188963826-xk
pookguy88
cars
Thanks for the reply, that's reassuring
oxnor
2024 Flash
Does anyone have the default 18 inch wheel circumference setting?
I just changed my wheels from 20s to 18s on stock tires, I set the circumference to 2560, and my speedometer is still off.
Thank you!
