So it looks like they left the button in the 24's and 25's. Yes I also get that Nav option PLUS another one that says Active Park Assist. It gives you several options:Bought my truck June last year and never noticed that button down there but I've got it, when pushed it brings up this.
Additional setting takes you over to the driver assist menu where parking sensors and others are toggled on/off.
If I click navigate to parking it just brings up the nav menu.
1. Parallel: If you're driving down a street and turn your right blinker on, it will look for a space to parallel park, then once you put the truck in neutral, it will take over and parallel park the truck in that spot.
2. Perpendicular: If you are driving down a parking row and turn on either blinker, it will search for an empty spot in that direction. Then once it finds one and you shift into neutral, it will back into the spot.
3. Exit Parallel: If you are in a parallel spot, it can get you out.
In all cases you hold down that same button while it does its thing.
Here's a video:
