Issues with climate control via the app
itsjmod
Jason
2022 F150 Lightning Lariat
Software Engineer
This just started and it’s pissing me off. I try to turn on climate controls and it just spins for a minute and then gives a warning ⚠ symbol for a second.
It works sometimes but almost 95% of the time it doesn’t anymore.
I’ve deleted the app, reassigned my phone as a key, deleted my phone and readded.
Ford is so bad at software I swear to god. I love the new design in the app but what’s the point if it doesn’t work
Software across the board is literally the only thing I regret about this truck.
Ford F-150 Lightning Issues with climate control via the app IMG_0215
Ford F-150 Lightning Issues with climate control via the app IMG_0217
sfringer
Scott
NC
It's possible your 12v battery is low, and the system has shutdown non-essential modules (the modem needed for this communication) to maintain charge to be able to start the truck.
itsjmod
itsjmod
Jason
Software Engineer
So it should tell me that then. I drive this thing daily including a couple hundred miles yesterday.
Why isn’t it communicating this stuff to me?
But thank you for a possible explanation, I’ll get it checked out.
sfringer
Scott
NC
I wish I could answer that for you. I'm seeing the same lately, with the colder temps, when I skip a day of driving my truck.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
I agree with your theory. My 12 volt battery is approaching 3 years and I've been getting the 'saving battery warning.' My Climate Control from the app has been taking much longer to start also, sometimes timing out like the OP mentioned. I've started to try to unlock or lock the doors to 'wake things up', and in my mind it seems to have helped. Getting 12v battery replaced in the next month.
Deleted member 19221
Guest
This has been ticking me off for the last few weeks. It's freezing cold out and I can't remote start the heat. My 12V battery is two-months old.
Webbo85
Marc
Glenmoore, PA
Mech Engineer
Then maybe it is an app or software glitch. I noticed it with my 12v battery issues so I was hoping that was the link.
Guest
Even when my truck is plugged in at home it doesn't work lately. I have to go out and open and close the drivers side door first. Then it beeps at me and fires up the heat. So odd.
What version of Ford App are you running 6.4.0, 6.4.1 or 6.5.0?
Have you tried switching off your phones wifi and using the cellular signal to test the malfunction?
PJnc284
Garner, NC
It's amazing how they have this big giant battery but can't keep the little ol 12v happy. There should never be an instance of the truck deep sleeping if the hvb has sufficient charge. They already supposedly have the logic there to charge it but for some reason chose 40% for 48 hours or < 30% as the threshold before sending the 300W.
Webbo85
Marc
Glenmoore, PA
Mech Engineer
I’m at 6.5.0. My Climate hasn’t worked at all today. With or without wifi turned on my phone.
Although I just turned on the Climate on my wife’s Mach e with the app. So that points to the truck.
chriserx
Louisiana
It appears you're on iphone, I can't explain for the life of me why the app sucks and/or takes forever, but I've had really good luck with the one click shortcut I made. I'll post the link but mods can remove it if it's against a rule.
https://www.icloud.com/shortcuts/db22f2883368468ba4f650f4634f93a6
You may have to modify it for your vehicle name in the app.
Edit: For whatever reason it is both faster and more reliable than opening the app and doing it, even though it relies on the app. If you want to extend the timer, just push it again after the truck started message appears. It's happened to me once, but I received the truck started message, walked outside and it wasn't started. ¯\_(ツ)_/¯
Yes, likely the LVB.
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Retired surgeon & jet aircraft pilot, Active rancher
It’s been real cold here and the auto setting wasn’t working properly. Manual settings eventually resolved the problem. ‘23 Lariat 30000 miles
Adventureboy
I share the frustration.
Given the number of us with the symptom, I think there may be a broader issue here. I've had poor success this past week with climate controls as well. It has been intermittent at best. My 12v battery is monitored and healthy, and on a trickle charger when it doesn't get driven for a day, and there has been no modem shutdown or battery saver mode for me. Climate control simply hasn't been reliable for the past week, although other communications like charging and SOC are working fine, so the modem on the truck is on and the app is working. I did get a BC 1.4 OTA update 5 days ago and I wonder if that introduced a glitch - have others seen the problem following an OTA, or is it a general problem?
I'm hoping @Ford Motor Company will fix the issue soon.
