Battery Conditioning Issue
Jfennell55
Jason
2024 Ford Lighting
Mechanic
It's been super cold last couple of weeks truck is parked outside and plugged in. I noticed that I have not not heard the truck fire up to warm the battery at all at night was working fine a couple weeks ago. I checked my home energy monitor for my charger and confirms that its not kicking on. I have a pixel 9 phone and android ford pass. Yesterday I was messing with my phone and every time I open the ford pass app. It locks up and I have to kill the app and reopen it when I reopen the app and refresh it all of a sudden I noticed that the battery conditioning message pops up on the app and I heard truck start warming the battery outside. I have re-created it multiple times killing the app and refreshing it and the battery conditioning starts working. Not sure if it's something with the app or waking up the truck when you refresh that gets the battery conditioning to start working. Seems like a bug
@Ford Motor Company
chriserx
Louisiana
I'm gonna assume that you know the difference between 'no communication' and a truly frozen app. There has been quite a bit of server side issues lately and I'm inclined to think that may be your frozen app issue, especially if it's not being handled gracefully. As far as the truck goes, I'm further making the assumption that you are talking about departure times as opposed to the battery conditioning when it's cold out. The majority of what I've seen people do is to try turning departure times off and back on, then removing and readding them. I haven't personally experienced this issue but it seems to resolve most of them.
Jfennell55
Jason
2024 Ford Lighting
Mechanic
Yes truck does not communicate with the app and have to kill the app and refresh then it starts working and no not talking about departure times. Talking about when the truck warms the battery when plugged in.
chriserx
Louisiana
AFAIK that is mostly variable, there are charts that show a correlation in outdoor temperature ranges like @TaxmanHog but it shouldn't be dependent on connectivity. That being said it may use connectivity for a weather forecast but this is strictly speculation on my part, but considering the relatively high energy cost to warm the pack, it wouldn't be a bad idea either.
I only see the battery pre-conditioning message if there is a departure scheduled.
When warming the battery otherwise, no messages.
I see from my FCSP Insights tab that the EVSE does use some energy even when not charging or pre-conditioning for departure, so I assume it is warming the battery with those Wh's.
It is not preconditioning though.
I think perhaps the preconditioning of the battery is different from just keeping it from freezing to death, and the preconditioning only happens when you schedule a departure.
But I don't have a lot of experience with using those setting in the app. so just speculating.
Departure Timed preconditioning uses more energy to raise the HVB to a higher temperature.
Spontaneous warming occurs randomly based on environmental status, it doesn't last as long in duration, sometimes 5 to 15 minutes and once done it doesn't repeat, though I'll admit that I drive her every day in the winter so I haven't observed if it'll repeat as needed.
The Ford App does not control the execution of either process, it is used to define rules for departure events.
Reactions: chl
PJnc284
Garner, NC
The app also says Preparing Battery and Cabin during the spontaneous warming. That said it seems 6.5 is a turd. I've had to restart my phone multiple times just to get the stupid app to connect and PAAK sucks even more than usual.
chriserx
Louisiana
Someone else reported this within the last few weeks, haven't seen it yet personally.
I think there have been a lot of PAAK problems reported on the forum - I use the FOB exclusively.
Preparing the "Battery and Cabin" is a departure preparation when you have one scheduled.
Go in you app and check to see if there are any lingering there and delete them (unless you want them).
As @TaxmanHog said above, the spontaneous warming for battery safety is different from the preconditioning for a departure.
There is often server delay with the app, and could be worse in some geographic areas if cell tx/rx is poor and error prone. Is there a transmission tower nearby? Other rf can interfere with the comms if nearby. Or if the cell tower is overloaded.
I had a couple times when the app would no longer communicate with the FCSP, and that lasted a bit over 2 days...I never figured out why it happened.
The other day I wanted to warm the cabin before going out to test the PPOB, and the app told be there had been too many remote warming requests, so go out and turn it on yourself (in so many words) ha! How rude!
Frustrating when things don't work perfectly, but after being an engineer for over 40 years, I am used to software and computer glitches...human glitches can be even worse!
PJnc284
Garner, NC
Never had one set. It was several app revisions ago that I noticed it but it did in fact show that message as it had me scratching my head a couple times. First time it happened, I was taking the dogs out and heard the truck making a racket and checked the app. Was always in the 20's or so when I saw it. Think the app just isn't smart enough to know when it's "keeping the battery happy" v actual preconditioning for departure. Haven't really had it plugged in when it wasn't charging lately but going to be cold this week so maybe I'll give it a try to see if it still pops up.
It is strange behavior.
I didn't think it would precondition the cab unless plugged in?
From the 2023 manual:
Preconditioning Your Vehicle
You can precondition your vehicle to warm
or cool the cabin and the high voltage
battery when you have your vehicle
plugged in.
You can charge your vehicle to
the targeted level and also make sure your
vehicle is at a comfortable temperature
for the occupants.
Note: You can precondition your vehicle
prior to your departure using the FordPass
app.
If your truck is "preconditioning" when not plugged in, then it is very confused!
PJnc284
Garner, NC
plugged in.
for the occupants.
app.
it was still plugged in from charging the previous afternoon.
Then, what you witnessed was a round of spontaneous warming, nothing to worry about.
OTOH, when the truck is not plugged in, then only cabin conditioning will occur, either by scheduled departure time (with switch on for "While Unplugged") or use of the remote climate start.
The sound the truck makes is the same for either process, circulator is moving glycol through the PTC then to the cabin heater core. or for those trucks with a heat pump, you will hear that operating.
Reactions: chl
It'd be nice if the manual had a flow chart about such things!
The way it is written leaves a bunch of question marks.
It would be nice, probably could find something with the paid online PTS manual system.
I haven't looked, but have relied on the general concept of this pictorial for the MME, it's likely close to what we have in the 2022/2023 Lightnings, without consideration of the Max Tow extra AC compressor and how the plumbing would be for that variant.
Also like to see the Heat Pump system as well.
Ford F-150 Lightning Battery Conditioning Issue 1769887002772-u3
Reactions: chl
