He probably meant PT-25.8.5. There‘s a thread on that but was closed and continued as PT-25.13.12.Could you give us screenshots from the SYNC or Ford App, showing the description for this OTA.
Also include the shot from the bottom of the listed description where the version number is listed.
This thread is title 28.8.5 and your response in another thread said 25.8.5, which is correct ??
Thanks for the reminder, I re-searched and found 25.8.5, I bumped that up the results list so other can read it and the subsequent thread.He probably meant PT-25.8.5. There‘s a thread on that but was closed and continued as PT-25.13.12.
Some folks reported charging locations deleted.
The spontaneous battery warming phase might have kicked on as needed, it's not dependent on an actual departure event in extreme cold.Even then...this morning it started the "Departure and cabin warm up" and hour earlier than scheduled? All my times are correct in truck and app and have it set to the right time zone? Hope it was just because the new settings...but I don't know?
It's been really cold here (Chicago) and never seen that before and last night wasn't all that cold? By the time I actually got in the truck to go to work...it was REALLY hot in the cabin. lolThe spontaneous battery warming phase might have kicked on as needed, it's not dependent on an actual departure event in extreme cold.
When there is a departure event, I've seen it start as much as an hour early in extreme cold conditions.
Try making the settings in the truck.Cant even enter the charge limit in the app while its charging. Just goes to 100% unless you manually stop it. As far as locations charged at my usual location (work) and won't let me add it as a target charge location. Does show any.
Very frustrating update as I don't want the truck charging to 100%
Will give that a try shortly.Try making the settings in the truck.
