If it fails again, you need to put the battery on a maintainer and also try running the truck
Thanks for the advice.By the way, maybe when they replaced the battery they didn't reset the BMS correctly, might try that (see a previous post in this thread)?
Thanks for the update. Having it charge overnight has worked for me too. But not always. I’ve had these inhibit updates fail on at least four occasions and all except one finally went through after different combinations of charging, running truck for 4+ hours, or battery tender. Back in ‘23 I had one fail for two weeks before it finally expired and never installed.The update ended up going through on its own without a battery tender or additional BMS reset. Had it charging on my FCSP Wednesday night (02/18)
Did not add that function to my 2023 Pro - still says PPOB can't be on unless the truck is on.The PCM controls PPO so hopefully that's all that is needed for PPO with truck off. Need someone who didn't get it to work before to try it now after this update.
As for charging speed on dash, hopefully this also updates the other two modules for that one too.
Did you make the needed Forscan change? It creates a slider on the PPO screen that allows PPO to continue when you turn the truck off. Also see this post.Did not add that function to my 2023 Pro - still says PPOB can't be on unless the truck is on.
Thanks for the link.Did you make the needed Forscan change? It creates a slider on the PPO screen that allows PPO to continue when you turn the truck off. Also see this post.
I share that concern, too. I figure if I miss my monthly DTE Energy SmartCharge reimbursement next month, I'll know why...for those who are enrolled in an incentive program with your energy provider (I'm with XCEL), you may want to verify that your Lightning is still active in the program since the update wiped previously stored data.
