Updates have affected all kinds of things not mentioned in the release notes.I have read the release notes as well; however, the reality is - WAL worked before update. WAL barely works post update.
I had a similar experience. Update failed several times over a few days, each time giving the 12V battery low message.This update failed to install for 4 days. It finally completed yesterday (13 Feb 26), but my scheduled charging times and target location data in the app are no longer there. The Welcome Lightning also stopped initially. I'm not sure what other issues,, if any, have resulted. Anyone else's update have something similar?
I have scheduled an appointment with the dealer as those first four failed attempts were attributed to the 12-volt battery power not being at a high enough power threshold (80%). I'm not really sure what they should check for now since the update finally completed.
Been there. Hook up a tender that puts out 13.5+ volts, not a smart charger, early in the day. Tender should be downstream of BMS. Then in the afternoon, turn truck on, but turn HVAC, radio, headlights off, and run truck for 6 hours. Have to also disable shutdown timer. After 6 hours, turn off truck and close all doors. See above about frunk being closed also (tender leads wont get crushed). Let the auto update attempt at 1am.I’m open to any suggestions.
Also unplug all 12V addons like dash cams, comma, obd dongles. Keep PAAK and key fobs far away (can turn off BT on phone also). Don’t try to monitor anything, leave the truck alone on the tender.
This is the max effort, clearly not everyone needs to do this. If it fails, start earlier the next day or get the battery checked and replaced if needed.
The problem with WAL is that it’s some sort of proximity situation. It needs to be time based like GM has had for years. Last door is closed and truck locks in 10 sec. Period. Makes no difference how close or far you are with the fob or phone. The way it is now. Sometimes I can be right outside truck and it locks. Other times I can walk a football field away and truck never locks. It’s always been very unreliable and never consistent.I have read the release notes as well; however, the reality is - WAL worked before update. WAL barely works post update.
I’ll do you one even better. How fucking hard is it to show whether the truck is locked or unlocked in the ap? Why are they updating dumb shit instead of fixing something this simple?The problem with WAL is that it’s some sort of proximity situation. It needs to be time based like GM has had for years. Last door is closed and truck locks in 10 sec. Period. Makes no difference how close or far you are with the fob or phone. The way it is now. Sometimes I can be right outside truck and it locks. Other times I can walk a football field away and truck never locks. It’s always been very unreliable and never consistent.
Goddamnit! Don’t get me started on the app interface.I’ll do you one even better. How fucking hard is it to show whether the truck is locked or unlocked in the ap? Why are they updating dumb shit instead of fixing something this simple?
NOIs there a way to save the charge location data so it can be reloaded easily I wonder?
Slightly annoying, but slowly becoming more and more annoying every time it happens.Alright finally got the update to take. I mistakenly had my 12v charger hooked directly to the battery instead of the connection points on the right side of the frunk. I also unhooked my comma.ai and fitcam dash cam for good measure. Even after doing this it still wouldn’t update yesterday evening or at the scheduled 1am time. This morning I tried again and it failed again. I walked away for a few hours still with the charger on.
I happened to check FordPass around 11am and saw that the update magically completed. Cant say with certainty what did it. Like everyone else it deleted my charge locations and %’s so that’s slightly annoying.
Went ahead and enabled pro power with the truck off for my 2023 on forscan since this updated the PCM.
Brian from Ford responded on the other PT thread (a different version number but the same package). See below for what happened and why this should be the last time:Slightly annoying, but slowly becoming more and more annoying every time it happens.
I only charge at one location, home, so I can only imagine how more annoying it is for people with multiple charge locations to have to redo them.
They ought to require programmers to actually USE the things they are updating, then maybe they'd have a clue?
Hi folks,
Jumping in here because I know how annoying it is to hop in the truck and realize your charge settings have vanished. I grabbed some time with the engineering team to understand what has happened.
Here is the lowdown:
The powertrain update is doing some housekeeping behind the scenes to make your stored settings more resilient during future updates. The catch? The system can clear current settings in the process. I know it’s a hassle to set them back up (it’s definitely not my favorite hobby either), but the good news is that once you do the team has said that they shouldn't be affected by future updates.
The update is rolling out now to 2022/2023 trucks with a version for 2024s coming in the future.
Thanks for bearing with us!
- Brian (not AI) from Ford
If you still have the original battery, it’s time to replace it.Just like some other folks, mine will NOT update this PT-25.8.5. Always getting the Low Battery message. Been hooked up to the battery maintainer overnight. Battery showing full. Try to initiate the install manually. No go. Battery too low message. Getting real tired of this crap. All doors closed, frunk closed, no accessories plugged in, etc.
