Rotary Shifter Part Numbers
El Duderino
2025 Flash Job 1
That’s interesting. I hooked up FDRS at one point when I had mine installed and it never showed any indication that it knew what shifter module was installed or that it changed. I even ran diag on it without any weird reports.
Thanks for the reply. I am learning about CANbus communication in my day job. My comments stemmed from some recent learning about how modules claim addresses and interact on the bus. I still have a lot to learn there.
In the days since I have gotten the DTC one more time. But it has gone away. I was reading about the ICE F-150 shifter problems and it seems like it could be from shifting too fast from park to drive after startup. I will try to replicate it.
wighty
NY
a few coats of sandable primer, then matte black paint, then matte clear with plenty of sanding along the way.
Which brand/paint codes did you use? It looks good and I think I am going to do this as well.
UncleTony
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Typically a manufacturer will share DBC's for every vehicle on the same platform (Module and software wise). So it isn't super likely that the shifter would be using different messages/message ID's as long as it is from the same platform. It would also more than likely cause faults all the time if the messages aren't what the other modules are expecting. It would be possible that it's not sending a message or sending a message in a different format under certain situations that the other modules expect/don't expect. Likely what causes the door/parking brake message some get with shifters that work otherwise.
Robocop
2022 Platinum; 1962 Lincoln Continental
Apologies for the delay getting back to you on this. I got my products at the good ol home depot and assuming you can get the same products where you are, I've attached an image of the exact products I used below. I sanded with some fine grit sandpaper between coats to smoothe the finish.
Good Luck!
Ford F-150 Lightning Rotary Shifter Part Numbers 1774549129063-4q
Backwardsfish
Pat
Vancouver, Canada
Lightning Flash (previously Mach E)
Jumping into this mod friends - and question with motorized vs non-motorized. Previous car to my '24 Flash was a '21 Mach-E with rotary shifter, non-motorized. I actually liked it because I could give it a long "crank" to the right and it would stop at D and I can keep spinning all day to the right and it just sat in D. Same for spinning to the left, it'll eventually stop in P no matter how long I spin.
The Question - for those of you with NON-motorized - I'd expect the behaviour to be the same. But all the talk here about motorized shifters makes me wonder if I keep spinning this thing - say to the right - is it going to stop at D or keep cycling through all the drive modes?
mr.Magoo
2022 Lariat ER, AMB
I can't answer for all, but my non-motorized e-transit shifter stops at D/P respectively, no matter how much you keep spinning.
JetMech
Collin
2023 Lariat
Got a new part number for the list. PZ1P-7P156-ED.
It was plug and play, and came out of a '22 Bronco Sport.
It has a blue ring around the base of the dial.
It is not motorized and electrically shifts back to P when you open the door in D.
"L" button activates N hold.
It will not rotate unless you push the brake.
It will rotate past D and P, but doesn't do anything.
Printing this cubby now. https://www.thingiverse.com/thing:7024287
gonna be nice to finally have a cup holder big enough for my giant water bottle!
I am looking at buying this PN shifter but in one of the pictures it has a tag that says "NO AMBIENT". Did yours also have that on it?
Ford F-150 Lightning Rotary Shifter Part Numbers 1779376160468-9
Space Flash
Richard
2025 F-150 Lightning Flash
EDIT #2: I ended up returning the shifter below. The quality just wasn't what I'd hoped for. I ended up buying an injection molded shifter from ManionMakes. The quality is excellent. More here: https://www.f150lightningforum.com/...hifter-part-numbers.29588/page-16#post-726667
EDIT: The gentleman making the complete rotary shifters I noted below has moved from FB chaos to an Etsy store of his own. Prices went up a little - expected I guess, but still seems pretty reasonable for everything including a brand new motorized shifter. I went ahead and ordered one and will report back. FWIW I ordered the one with a "cubby" rather than having a 3rd cupholder.
Here's a link to his Etsy store:
https://automotiveplastic.etsy.com/
Hi All! There's a gentleman named Matt Kre selling complete rotary shifter kits on FB for $130 shipped. I know I could order the parts separately for less, but seems reasonable for a quick DIY. Just wanted to check to see if anyone else has bought one from him and is satisfied.
MODS: Feel free to delete the link (or my post) if it's not allowed.
TIA!
SFsparkie
2023 F150 Lightning Lariat ER 01/23
I too bought a lj9z7p155d from ford in March of 2025 in anticipation of my OEM GSM going bad some time. it went bad this week. I installed the lj9z7p155d and it immediately pulled two DTC related to the GSM and ABS. Can’t clear the codes either.
mr.Magoo
2022 Lariat ER, AMB
Numerous people have had issues with the Mach-E shifter to the point where you probably should avoid it and go for Bronco Sport, Escape or E-Transit.
dancwilliams
Dan
Louisiana, USA
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash (Job 2)
I purchased a rotary shifter on eBay that is not on the list that works. I've not tested it beyond my driveway because my adapter hasn't arrived yet. But since I gambled on it, I wanted to plug it in and make sure.
  • LX6Z-7P155-L (I believe this is an older part that was superseded by -U, the box and date code on the shifter says March 2021)
  • Motorized
  • Ambient Glow
Ford F-150 Lightning Rotary Shifter Part Numbers 1784587073052-c
Plug for ManionMakes on Etsy. They're selling an injection molded version of the adapter now that looks absolutely OEM. Super excited for it to arrive.
Injection Molded F-150 Rotary Shifter Adapter - 2021-2023 / 2022-2026 Lightning | OEM Console Upgrade Kit | Ford Truck Interior Accesso - Etsy
Ford F-150 Lightning Rotary Shifter Part Numbers 1784587365344-lq
Shmoe
2024 F-150 Lightning Lariat, 2025 Rivian R1S, Sold-2020 Tesla Model 3 SR+
  • Motorized
  • Ambient Glow
I've been staring at this in my etsy cart for some time now.. def gonna pull the trigger on it soon. So awesome.
