Rotary Shifter Part Numbers
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash
I ordered a second version from the original supplier of these Manion Makes after he introduced a "finless" version of the binnacle, which I much prefer.
Taking inspiration from the OP, I hit mine with a few coats of sandable primer, then matte black paint, then matte clear with plenty of sanding along the way. This looks closer to factory than my first attempt using a satin clear to finish, which was much too glossy.
I wanted it to turn out nice and not look rough and unfinished. I am no painter by any means but I took my time and I'm pretty happy with the result.
Looks really good! Probably going to try this myself.
Bandit216
Alaska
Mach E GTPE, Lightning Lariat
I went with the @PolymerBuilt version referenced above, but I agree, yours looks nice.
wighty
NY
Is LX6Z-7P155-X the only motorized one with rubber? Any idea what vehicle it came from?
wighty
NY
sounds like the bronco shifter.
Seems most of the others were starting with P, and I haven't been able to pin down what exact trim it would be from to search for it. If I can't find it I guess I will get one without the motor since it is like $60-80 vs trying to get the new one that has the motor ($230ish).
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
I've installed PN# LJ9Z 7P155D Mach-e Rotary Shifter in my 2022 & 2023 Lariats and now getting a DTC for the GSM DTC P0929(77). I've updated all the modules with FDRS on the 2023 LER & thought that might fix it, but it's still showing up. How to fix ?
The Weatherman
Dean
South Central KY
The Mach-e shifters have been flagged here as having issues if installed in the Lightning. Your best bet will be from an Escape of the 2021-2023 time frame.
El Duderino
2025 Flash Job 1
I have an Escape shifter LX6P-7P155-ED that has worked flawlessly for 6 months until last night.
I am getting DTC U0103 code in the Secondary OBD Control Module B and
in the Gear Shift Module (GSM) I am getting
===GSM DTC U0100:87-AF===
Code: U0100 - Lost Communication With ECM/PCM A
Additional Fault Symptom :)87):
- Missing Message
Status (-AF):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Gear Shift Module
===END GSM DTC U0100:87-AF===
Clearing the DTC with Forscan doesn't fix the issue, the DTCs come right back.
Any ideas? I am confident it's an OEM Ford shifter:
Ford F-150 Lightning Rotary Shifter Part Numbers 1772916283698-lh
mr.Magoo
2022 Lariat ER, AMB
It's not like rotary shifter are immune to issues, and if they're bought used I'm sure it's even sketchier - doubt Ford specifically prints "replaced if dropped" on 'em for fun.
Karlos
Karl
DFW & Kerrville Tx
So there should NOT be any DTC's with a suitable replacement ?
Do you have to tell the truck you've changed the part ? VIA FDRS maybe ?
digitaldad
ABQ
2023 Lariat ER MaxTow
I've had mine in for some time, no FDRS/FORScan tinkering needed.
EDIT: Regarding DTCs, I went back to my original post when I installed: I only had DTCs when I started truck without any shifter installed, and then when I installed rotary...but I hadnt securely seated the connector (slider-lock) correctly/fully.
The Weatherman
Dean
South Central KY
Nope.
Plug and play.
El Duderino
2025 Flash Job 1
Update:
I re-installed the original Lightning shifter and the DTCs went away on their own...
Then I unplugged the original shifter and plugged in the dial shifter... Drum rolll... No DTCs...
Maybe the CANbus message stays flagged until it sees a new shifter module by some unique identifier?
I didn't just unplug the dial shifter and then plug it back in. I should have done that first.
I am taking a J1939 protocol training this week, maybe I will be able to answer my own question in a few days...
UncleTony
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Update:
That’s interesting. I hooked up FDRS at one point when I had mine installed and it never showed any indication that it knew what shifter module was installed or that it changed. I even ran diag on it without any weird reports.
