joshtb86
- Mar 11, 2026
- New Jersey
- 2025 f150 lightning flash
Do the same issues exist in the 2025 models? Dying early etc?
YESDo the same issues exist in the 2025 models? Dying early etc?
Battery maintainer like a trickle charger? Are you plugging that into the pro power bed in the frunk? Got a solar one that plugs directly in to the OBD2 port for on the battery itselfYES
Battery swelling too
Check all connections on the battery. I mean ALL connections.
i found them loose and somewhat oxidized. Check under the BMS on the negative terminal. Mine was not tight and could hear a hissing sound like a loose connection. I cleaned the oxidation off the contact areas and used dielectric grease (silicone) on all the connections and made all the connections tight.
I bought a NAPA battery. ( there are only 2 manufacturers of this battery, one with the waffled sides like Ford, etc or flat sides like the NAPA. Don’t forget to reset the BMS.
And a 5 amp CTEK battery maintainer.
No, you don't want to use the truck outlets to power a battery maintainer that charges the 12v battery...Battery maintainer like a trickle charger? Are you plugging that into the pro power bed in the frunk? Got a solar one that plugs directly in to the OBD2 port for on the battery itself
I hope the order was clean, then tighten, then apply the dielectric grease over top.cleaned the oxidation off the contact areas and used dielectric grease (silicone) on all the connections and made all the connections tight.
Yeah, many improperly use dielectric grease.Mine lasted 3 years and 3 very cold winters before I proactively replaced it before leaving the truck parked for a week unplugged at - 25 deg C this year. Bought a new one from ford that has a 3 year warranty. No problems.
I hope the order was clean, then tighten, then apply the dielectric grease over top.![]()
Truck outlet to power the charger sorry should have clarifiedNo, you don't want to use the truck outlets to power a battery maintainer that charges the 12v battery...
If you use a battery maintainer, either connect it to the jump posts, or make sure the negative is south of the BMS connector.
What do you mean just put on top?Yeah, many improperly use dielectric grease.
You don't want to use ProPower to power a device that is used to charge the 12v battery.Truck outlet to power the charger sorry should have clarified
It is non-conductive. If you coated the battery terminals, then put on the clamps, remove them and clean all the grease off. Apply the clamps and then tighten. Then, apply the dielectric grease if you see it (totally unnecessary).What do you mean just put on top?
Dielectric grease is to keep out moisture and prevent conductivity.What do you mean just put on top?
Ford has not significantly changed the 12V battery management.Do the same issues exist in the 2025 models? Dying early etc?
There were updates to the 12v BMS over the past year. Those greatly improved how my 24 Flash manages the 12v battery - it was very evident this winter. I recall getting one or two updates OTA that affected the 12v system but I’m not sure if there were others - I keep my trucks updated with FDRS and you don’t get the nice summary when you update that way.Ford has not significantly changed the 12V battery management.
In general, the lifespan of 12V batteries in EVs is about the same as in gas cars, roughly 3-6 years, mainly depending on your climate: the hotter it is, the quicker 12V AGM batteries will die.
Unlike gas cars, most EVs have electronic locks and latches, which sets up a catch-22: you can't access the vehicle without 12V power, but you can't jump-start the vehicle or replace the 12VB battery until you can access it.
This isn't the case with the Lightning: you can access the vehicle to jump-start it using only the key that's inside the keyfob. That plus a lithium-ion jump box (or another car with jumper cables) is all you need to get going again.
