The saga continues… I Love My F-150 Lightning. I Hate My Charge Station Pro. I Want A Refund
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
It’s been another silly week in the progress toward… I don’t know what.
Ford flew someone out… yes it’s broken… yes I’m getting another replacement…
K6CCC
Glendora, Calif.
Have not watched the video, but I am happy with my FCSP. Granted that it is overkill for me as I only have a 48 amp on board charger and I have zero expectation to ever use it for the Home integration System (or any equivalent). Had I known better at the time, I would not have bought the FCSP because of those two items as I could have spent quite a bit less on something else.
My only complaint (and it's minor) is that Insights on the charger on the Ford app only shows power flow at the time that you unplug the cable. And if I had bought a 48 amp J1772 EVSE the cable would have been smaller and lighter (not a big deal for me)...
My fcsp arrived at the end of 2022, it's been installed outside in the shade for 3+ years at 48 amps with no issues. Heat is bad for electronics.
The FCSP is generally fine……as long as you‘re not trying to use it with the HIS home backup installation.
Reactions: chl
Pitbull2o08
Ohio
My replacement was shipped out to a different address that isn’t listed in my account. I can’t make this up.
RLXXI
3rd rock
Automotive Technician
FCSP came with the truck so free beats any other price. ;) Haven't had any issues with it charging. I use the truck battery as home backup but set up differently as it's combined with a solar system I built and whole home genset so none of the HIS issues I've read so much about. My blood would be boiling if I had bought that system and have it not work.
tearitupsports
Russell
Cypress, TX
I apologize I have not reviewed the video yet, but what (hardware dial position) rate do you have the charge station set to? Since day 1 I have my FCSP turned down to 64, and now down to 40A. I haven't had any sort of issues or connectivity problems in over 3 years of having it. Even with the HIS system.
davehu
hot springs, AR
I love my Lightning AND my FCSP. Have had both for 2 1/2 years and the FCSP has functioned perfectly.
Aminorjourney
Aminorjourney
Nikki
Internet
Its on a 100A circuit and charges fine... but that's it
tearitupsports
Russell
Cypress, TX
Sorry, but I specifically mean what you have it set to. Mine is too on a 100A breaker but it is still only set to 40A.
Observing a lot of posts, it seems that most people who have issues with FCSP are set to 80A where there is a lot more heat generated. Those of us with lower settings have less issues in general. I am sure there are exceptions on each side, but the majority of issues follow what the max current setting is.
Aminorjourney
Aminorjourney
Nikki
Internet
That's worth looking into - Maybe I'll get them to turn it down when the install the new one? :)
Reactions: chl
Steely
SE Mass
2022 Lightning Lariat
We should build a FCSP serial database, I wonder if the early units were more prone to fail.
I am on my 3rd the first 2 had the modem chip or whatever is responsible for Wi-Fi and Bluetooth die, charging worked fine and it looked normal. If you never use the HiS or checked anything via Wi-Fi you'd never know. I noticed it always would drop the wifi connection and would fail to allow connection to the settings and status pages before mine failed entirely. At that point the reset button didn't reset it and it wouldn't broadcast or connect to any Wi-Fi. No Bluetooth no HIS transfer.
I also recall it would never allow limiting the charge in software.
So far (🙏) my 3rd unit is working properly, all the above issues are solved. The software charge derate also works mid charge, no replug required.
I noticed the new unit has a different id on it. The first units were SWA### but the new one is SWA###FW. Did they revise the hardware? The antenna in the device still sucks, it is 3ft further away from the wireless access point than the delta inverter but it is -30dB reported signal level than the inverter.
Also my previous units were never used to charge the truck I always charge for free at work. So overheating due to high amp charging should not apply. I also have the unit installed indoors so it is not exposed to extreme temperatures or conditions.
Pitbull2o08
Ohio
when you got the 3rd unit, did the HIS work better?
