Possible radiator leak?
NAVEWO
Tucson, Arizona
2023 Ford F150 Lightning Lariat ER Max Tow
Retired USAF Navigator/Electronic Warfare Officer
Anyone have an idea about this dark spot on the upper part of my radiator. I’m afraid it may be a leak but thought I would check with the collective. I pulled a Kleenex and a few small leaves out of the radiator area but nothing like stones or harder debris.
Ford F-150 Lightning Possible radiator leak? IMG_0894
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Is that a picture of ur radiator or condenser? What does the coolant overflow reservoir show?
MountainAlive
Massachusetts, USA
If still under warranty I’d consider bring it in to be looked at. But you could also take out the frunk tub to get a better look at where it might be coming from.
NAVEWO
NAVEWO
Tucson, Arizona
Coolant tank was between min and max. I know it was on max last year so definitely down some. I brought it up to max and will continue to keep an eye on that.
NAVEWO
NAVEWO
Tucson, Arizona
Looks like the ac condenser.
I may not have my terminology correct by calling that assembly a “radiator”. I have the max tow package so that being the case this is a split system feeding two separate compressors ???
NAVEWO
NAVEWO
Tucson, Arizona
I just went over 3 years a couple weeks ago. My plan is to wait for parts to be available for the light bar recall and have the dealer look at it then when I have to take it in for that service.
NAVEWO
NAVEWO
Tucson, Arizona
Only one ac compressor that I'm aware of.
Munro Live episode on the Lightning cooling system shows the Max Tow package adds a second compressor.
This video explains the HVAC system:
But was that your heat exchanger that's at the front of you vehicle?
You mentioned leaves but no stones, so that's what I'm thinking it is - see this video:
In that case, it could be a coolant leak not an AC refrigerant leak (unless that is your evaporator) if I understand the arrangement of the systems correctly.
Keep an eye on your reservoir located on the driver's side of the truck under the frunk hood.
roddiaz1
Rod
Pittsburgh
Cooling system and refrigerant system for the ac are two separate systems. Regardless of any of that, it still looks like the ac condenser is leaking.
Mine just got replaced for leaking after 40 months and 56k miles (out of the original Ford warranty). Problem is the repair did not last long and it’s going back in next week to get re-fixed.
Seems we're all dealing with the intricacies of these machines, mine is at the dealer for the trailer module flash recall and the shifter was acting up, wouldn't fold, if you open the door in gear, it use to auto shift to park, now it stays stuck in drive, shifter locked and the D light flashes, at that point the truck is on, the accelerator is non responsive. Have to disconnect the 12v batt to get it back in park, which oddly enough, it goes back to park on it's own after reconnecting the lvb lol.
I fear there may be some chinesium involved. :bandit:
Unfortunately the folding shifter is an on-going problem inherited from ICE F-150 according to a bunch of YouTube videos I've seen...
There were a couple of ways to unlock it when that happens, but they didn't mention the 12v battery disconnect I don't think, mostly they said it was a mechanical problem with gears/motor as I recall.
Several people have switched to a rotary shifter. I just try to avoid the auto-movement and keep my fingers crossed.
I made a collection of links in case it ever happens to me, and now I know to try a battery disconnect too!
NAVEWO
NAVEWO
Tucson, Arizona
Took my truck in yesterday for the recall, the oily stain on my condenser, and I asked about the three year brake fluid change. I got the truck back today with the following.
26SB6 Lightbar recall: The truck passed the lightbar recall inspection and Ford approved the pictures. So recall complete for me and no parts needed.
Oily stain on a:c condenser viewed through louvers. Truck is out of warranty so paid $200 for an A/C diagnostic to check on the greasy looking condenser stain. See my post on this stain.
https://www.f150lightningforum.com/forum/threads/possible-radiator-leak.36407/
No leaks found. They pulled all the Freon from both systems (max tow package) and found no decrease in specified levels. They cleaned the stain for me and I guess I’ll just monitor cabin, battery, and motor cooling.
They seemed unaware of the 3 year brake fluid change recommended in the owners manual. Service advisor said they generally recommend fluid changes at the 5 year point. Pretty dry climate here in Arizona so I’ll kick that can down the road to 4-5 years.
My understanding of the heating and cooling systems in my 2023 F-150 Lightning - some later years have a heat pump, mine does not...
The max tow package does NOT use Freon to cool the motor or battery - it uses the --a refrigerant to cool-- the same Motocraft P-OAT Coolant as --is done in-- the systems without the max tow package. The battery and motor coolant loop (an additional loop = two loops with the max tow package) are separate from the HVAC A/C system --but a control valve can loop some of the refrigerant through a chiller to cool the P-OAT that cools the motor and battery--.
"Freon" is not used for the HVAC A/C system it uses "R-1234yf an eco-friendly and highly efficient refrigerant" which is different from Freon and does not punch a hole in the Ozone layer of the earth the way Freon did. It does not contain Chlorine and breaks does within 11 days in the atmosphere on average, so they tell me. It has an Ozone Depletion Potential 9ODP) of zero.
To warm the cabin, the resistive heater (PTC - Positive Temperature Coefficient heater) heats the P-OAT liquid which is circulated through a heat exchanger behind the dash and air is blown over that to warm the cabin. The PTC is also responsible for warming the battery. Diverter valves change to flow of the liquid depending on how it is needed.
Anyway, that's my understanding.
It seems the Ford mechanics are misstating what they did if they said they pulled Freon from the max tow system.
{EDITED to correct my mistake about the cooling}
K6CCC
Glendora, Calif.
My guess is that the use of the term Freon is old memory usage. People will be calling AC refrigerant "Freon" for the next few decades.
And yes, my understanding of the system matches what you said.
Yes old habits die hard...
Glad I got the system right. ⚽ ⚽ ⚽ ⚽
There IS a 'freon" based HEAT EXCHANGER to cool down the glycol based coolant.
Yes, Glycol circulates in the HVB and drive motors.
The drive motors have an OIL to GLYCOL exchanger as well, moving the motor heat to the battery pack in winter and further up the coolant conversion process to the freon based heat exchanger to boost heat extraction when the GLYCOL radiator can't cut the mustard.
Item #9
Ford F-150 Lightning Possible radiator leak? 1781322032035-hx
Ford F-150 Lightning Possible radiator leak? 1781321985902-5k
Reactions: chl
