Jim Lewis
- First Name
- Jim
- Jan 10, 2023
- San Antonio, TX
- Honda Accord 2017; 2023 Lariat ER
- Occupation
- Retired
While discussing the Home Integration System with someone, it was pointed out that automatic BPT (and the Home Integration System) has become a "non-person" with Ford, and transfer using PPOB via a Generlink switch is now officially the new thing with Ford.
Ford web page on BPT troubleshooting, relevant text copied below URL: https://www.ford.com/support/how-tos/electric-vehicles/home-charging/what-is-ford-home-backup-power/
IIRC, on the general BPT page I linked to, it mentions that the Home Integration System requires an FCSP, and, oh, BTW, the FCSP is no longer made. Generlink transfer using PPOB gets first billing on the Ford BPT web page.
There is further discussion of Generlink availability and use in the following thread: https://www.f150lightningforum.com/forum/threads/new-generlink-option-tn-and-utah.35784/
No mention of troubleshooting automatic BPT.... Just the manual solution.Automatic Home Backup Power Troubleshooting
Before attempting to troubleshoot, ensure the following:
Plug Cycle Home Backup Power
- Your home and F-150 Lightning meet the requirements for Home Backup Power.
- Home Backup Power has been set up and activated.
- The vehicle's rear passenger-side corner is closest to your charger. This ensures a strong Bluetooth connection.
- The rear passenger seat is folded down to minimize obstructions between the antenna and the charger.
Home Backup Power should now be active.
- Turn on your F-150 Lightning.
- Unplug it from your Charge Station Pro.
- Wait at least 30 seconds.
- Plug in your truck.
Note: You may need to repeat this process several times to trigger Home Backup Power.
