K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
I've been seeing something lately that is happening often enough to see a pattern. Wondering if anyone else is noticing the same.
At home I have a FCSP that has the switch dial set to 48 amp max charge rate and it's fed with a 60 amp breaker with less than 10 feet of THHN in conduit between the panel and the FCSP. My '24 Lightning has a 48 amp on board charger. I am on a Time Of Use rate such that my low rate starts at 2100 each night so I have the location setting for home set to only charge from 2100 - 1600 every day.
This is now happening most of the time. If I plug in prior to 2100, I will almost always first show Waiting to charge at 2100, and after about 30 seconds, I get a charger error - as reported by the Ford App. Most of the time, the indication on the truck is that the ring of lights goes out. Disconnect and reconnect does not help. Power cycle the FCSP does not help. Waiting till after 2100 and disconnecting the reconnecting almost always results in a normal charge session.
Friday night, when in the charger error state, after 2100 I disconnected, and just waited. While disconnected, the FCSP appeared perfectly normal (Blue light). After a short wait, I got the red ring of lights on the truck, but that cleared after about 30 seconds. I then plugged back in and charging started and continued normally.
FCSP Software version: 2.112.125:3.15:3.15:3.15:3.15
FCSP Model name: 1.0.0
FCSP Model number: 8EM1314-8CW16-0FD0
FCSP Firmware version: 5.0.25
Any thoughts?
Any thoughts?
