dmd3home
- First Name
- Dan
- Apr 20, 2022
- Central Coast CA
- 2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
I posted several months ago about an issue where PPOB would shut down on its own apparently thinking it had reached its "reserve" setting....sometimes with, or without a warning. That issue has much improved....had it happen a couple times in the last several months. Since then I have been thrilled that a hidden update has given me the ability to run PPOB WITHOUT having to have the truck running! Yay Ford! Indeed, things are improving. But this latest issue has me baffled.....when I try to engage PPOB, I get "PPOB Unavailable" (see photo).
I'm a heavy user of PPOB, in fact, that's the reason I bought the truck. I use it to power my house in outages, power varies tools while working around the property, and, to charge my other EVs. It's a rolling power supply. The truck is charged via an off-grid solar array and so is constantly being charged when not in use and I can almost always be driving on "sun power".
But today I performed a rather large charge to my Tesla Y...from 30% to 79% (with no issues). I did need the Tesla so shut the charge down at 79% rather than the set 80%. This charge session drained the truck from 80% to about 25%.
Later in the day I returned and thought I'd continue charging the Tesla to 80%, but when I fired up the truck and went to PPOB it said "Vehicle must be Running" to use PPOB.....Wait, I had the update to allow it to supply power with the vehicle off. Why am I getting this?? It's worked great for months now! So, anyway, I "Run" the truck and again go to PPOB and now it says it is "Unavailable...try later" (see photo) ......why? I've never seen this before! I did remember that every time I started it fresh that I always had to again reset the reserve setting to 10 miles (it always defaults back to 60 miles on shut down) and, would have to again tell it to operate even when the "truck is off" (I do wish it would keep my settings). So perhaps at 25% it thought the reserve was too low to even start. Maybe?
But the problem was that with PPOB "Unavailable" I couldn't even get to a screen to change any settings....well, I could get to screens, and scroll down, but everything was greyed out so couldn't see or change any settings. See photos.
But I did think, well, if the truck thought the reserve was insufficient, I'll just charge the truck and get it to a high enough level that it would surpass the apparent (apparent because it doesn't show up on the greyed out screen) default reserve of 60 miles. So I charged it to 35% with an on-grid level 2 charger. This certainly gets the present range above the 60 mile reserve that I'm guessing it defaulted back to (again, the present setting isn't available on the screen).
I did, somewhere, get to a screen that said to reset PPOB read the manual. Well, I couldn't find anything in the manual about "resetting" PPOB other than a ground fault or overcurrent breaker trip. Oh, and note that I have nothing plugged in anywhere.
I thought maybe if I drove the truck things might reset so I drove a few miles, came back and tried again......same thing!
Anyone have any ideas on what's wrong here?
Thanks
Thanks
