AlaskaFlash
James
Juneau, Alaska
2024 F150 Lightning Flash
My 12 Volt battery went bad, bulging sides, Only 2 years old. Replaced with a new Motorcraft AGM H3 under warranty. This battery went bad after two weeks with bulging sides. Battery saver notices showing up on Ford Pass. I replaced it myself with a H4 AMG battery that says it's electric & Hybrid compatible. I also reset the BMS by using the 5 bright headlight switch followed by 3 brake pedal trick. It seemed to reset the BMS. I had to cut off the spacers in the tray so the larger battery would fit. I've attached photos.
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0848
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0851
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0847
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0852
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0853
Zed
Chuck
2022 Lightning Platinum Rapid Red
For those of you who have installed the H4 battery in your Lightning: how is it working out? I know there's been a lot of discussion here about if/how well the BMS can deal with the extra capacity of the H4. I was considering doing the swap but decided to hold off and let the intrepid folks here blaze that trail.
I'm probably not the only one wondering about his, so please respond with your experience and any thoughts about it.
Thanks!!
Adventureboy
Adventureboy
I'm probably not the only one wondering about his, so please respond with your experience and any thought about it.
Thanks!!
BMS handles it no problem. I did mine in early March and no issues. 12v related messages have disappeared (although it is still summer).
Reactions: Zed
The Weatherman
Dean
South Central KY
Martin Meeks and Zach Carpenter have a retrofit tray for this, if anyone is interested.
I personally think it’s a little pricey, but others may not.
Lyle
Lyle
Hawaii
2023 Ford F-150 Lightning Platinum ER
Yeah I think it comes out in September. I’m waiting for Martin’s to get back to me on shipping costs because I’m in Hawaii and he said free shipping was to 48 only. I think the kit also comes with the battery negative terminal extension cable as well. Certainly pricey but it’s supposed to allow drop in replacement without having to remove the tub.
Blochead21
PA
Black 22 XLT 311pkg
Thanks!!
No issues here either. Glad I did the upgrade. Should also make a swap in the future easier with more choices while out on the road.
VAL.ABAPO
2025 F150 FLASH LIGHTNING 131kwh ER
I was thinking of using an H4 as well until i heard and seen Martin Meeks method.
im all for no mods on the battery tray.
