12V battery replacement poll
Will you replace your 12V battery proactively or when it fails?
  • Total voters
    211
PA Lightning
Tbone
PA
2025 Flash, 2022 Lightning Pro(traded)
I just replaced my OEM 12v with the OHMMU 12v Li-ion with a 4year warranty and it was less than $400.00. Sure still expensive, but it is designed to work better and longer in an electric vehicle that is notoriously hard on lead acid/AGM batteries.
The fellow in post 91 reported that the OHMMU Lithium is not available until March 2026 and that he received a Sodium. Did you actually get a Lithium?
The Weatherman
Dean
South Central KY
Yes. Ordered it about 2 weeks ago. It had a 20% discount offer at that time. And it was priced at $400.00 not $479.00.
Under $400 I'd consider it, but the list price at the moment is $480. I'll have to put their site on my watch list to see how often it comes on sale.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Added mine to the list of replacements, in warranty by a month. 2023 Lariet ER @ 27,745 miles. Started getting the "Battery Saver" mode last month. Truck normally sits in garage for 2 weeks while I'm away. Typically find it at ~ 60-70% SOC. OTA updates get stuck, haven't seen one go thru since July & still don't have BC 1.4 . Cheapo trickle charger didn't seem to keep up or figure how to charge it up. I'm going to try my aircraft AGM maintainer on the new one.
RSMLightning25
Richard
Schertz, TX
2011 FX2 F-150 5.0 Blue Flame, 2025 Lariat Lightning Anti-Matter Blue
Network Security
I chose other. I'll replace mine when I start to notice gremlins that are usually associated with a battery that's on it's way out.
mr.Magoo
2022 Lariat ER, AMB
The Weatherman
Dean
South Central KY
The Weatherman
Dean
South Central KY
There is something off with the picture of the installed battery. In my case I had to turn the battery backwards to that photo in order to connect the positive terminal.
It may be that the OHMMU label was put on the opposite side of that battery, but it could be that battery was installed with the polarity reversed.
Odd for sure? 🤔
mr.Magoo
2022 Lariat ER, AMB
Backwards?
Isn't your positive terminal on the right like in this picture ?
If the polarity was reversed I doubt it would have worked at all, let alone 7 months.
Ford F-150 Lightning 12V battery replacement poll 1765816624472-dh
The Weatherman
Dean
South Central KY
Backwards?
No. With + on the right, the label is then on the back. The front is blank on mine.
Agree, I missed that 7mo install.
klossfam
Jeff
East Amherst, NY
2022 Lightning Lariat & 2022 Hyundai Ioniq 5 Ltd
My original 3-1/2 old 12V is showing 100% SOH and 426 CCA but SOC is usually low after sitting overnight in the cold (35% or so SOC).
It works but past EV 12V experience says we are nearing the EOL. All my vehicles have a lithium jumper pack, but I'd rather not have to use it.
I wish the Ford EVs were set up for H5 Group size. A lot easier and less expensive AGMs. Used by all Hyundai/KIA and GM Ultium EVs.
klossfam
Jeff
East Amherst, NY
Regardless of the type of car, I charge battery at 3 years or less. I hate getting stuck.
Definitely a wise way to operate. This is first 12V I've had in an EV that made it this long. I wish H3 AGMs were $129 like H5s.
Weise is a very good aftermarket AGM for EVs but they no longer sell H3 size.
MrLoganRoss
Logan
Seattle Washington
'23.5 MachE GTPE & '24 Lightning Lariat
Yep. Learned my lesson twice with my Volvo ICE wagon. I think batteries tote the last 15 years have been designed to expire.
